Go Back   VAF Forums > Regional Forums > Southeast
Old 10-30-2011, 09:59 AM
strike4330 strike4330 is offline
Unhappy Grounded in SC. Looking for a ferry prop
Hello Guys and gals. My Aymar-demuth prop has developed a crack and I am now grounded in Beaufort SC. Will be driving home today but any help would be appreciated to get my plane back home. Catto prop will be ordered on Monday but I know they have some lead time, so if anyone has a spare prop that I could use for the ferry back to West Palm Beach, I would appreciate it.
My Plane is an RV-6 and has an IO-360-A1A, with 1/2" bolts.
Thanks in advance,
Jason
Last edited by strike4330 : 10-31-2011 at 08:53 AM. Reason: Adding more details. Thanks mike!
Old 10-30-2011, 10:04 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Jason, sorry to hear you are having problems, but I think you need to post particulars of the aircraft if you are going to get any useful assistance.
What engine are you running, what airframe. What range of prop diameter, and pitch do you need, bolt hole size. ETC.
Good luck, folks here are a good resource in your time of need.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 10-31-2011, 10:49 AM
664781 664781 is offline
Jason,
'Check your PM's....
Kurt Lohmueller A&P, DAR
Powder Springs, Ga
RV6A "Kurt's Toy" - Flying
RV12 - Flying - Sold
Old 10-31-2011, 11:44 AM
N941WR's Avatar
N941WR N941WR is offline
Check your PM's.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-31-2011, 11:46 AM
N941WR's Avatar
While we are waiting to hear from Jason, can any of you fly a two bladed prop from Charlotte, NC out to him?
I have a bad head cold and I'm not going above 50 feet.
Bill R.
SC86 - Easley, SC
Old 10-31-2011, 01:11 PM
gearup gearup is offline
Default prop woes
PM me.. I am up the road from you in Cocoa Beach, have a 70 x 70 and a 69 x 70 for my -18 SAE 2 bolt patterns, 1st is a Warnke, the 2nd, I dont know.. have flown behind them both, should get you back to PBI area no sweat
Jeff
Old 10-31-2011, 01:16 PM
****, sorry, both are 3/8" bolts... I do have a fresh ovh 76MM sensenich for my 180 hp cherokee your welcome to as a last resort..
Old 10-31-2011, 01:38 PM
GregM GregM is offline
Default Sorry for your misfortune
Correct me if I'm wrong here.... If you put another prop on, other than the same exact make and model, doesn't that throw you back into phase 1 requiring 5 hrs test flight time? Or, are you including that in your endeavor to get back home? Just wondering with the various prop models being thrown around. Good luck, wish I could help.
Greg Morgan, A&P
RV-8A, Phase 1 @ KDKX &
TN08
Oak Ridge,TN
Old 10-31-2011, 02:06 PM
N941WR's Avatar
It depends...
Going from one FP to another FP should not put you back in the box. However, going from a FP to a CS prop will. At least according to my FSDO. I checked when I was testing props.
Bill R.
SC86 - Easley, SC
Old 10-31-2011, 02:10 PM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Originally Posted by N941WR View Post
It depends...
It depends on your OL's. Mine are older and state that a change in make and model of the prop will require Phase 1. I'm working with Mel to get my OL's updated so that I can change the prop make and model and not have to return to Phase 1.
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
