I'll second the use of the MS21042 whenever possible. These are used on my "company" airplane almost exclusively and after years of working with them, it just seems wrong to use the standard locknuts supplied by Van. I swap them out whenever I can.
While substitution of washers my not get you much in savings, it is a great attitude to have during the build. You could certainly look at the "L" (thin) version of steel washers to get you a savings as well. In many cases, the thick version supplied by Van is way overkill for the application.
As an example of another extreme weight saving measure, my company airplane also specifies that thread protrusion through a locknut only has to be "flush" rather than the typical 2 threads showing. Not suggesting anyone do this on the RV, but it's an indication of a good mindset to have.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
