Old 10-29-2011, 08:45 PM
glenn654 glenn654 is offline
Default manufacture date?
Does Vans publish the manufacture date by kit serial number?
Glenn Wilkinson
_____________________________________________
RV-4 Sold
N654RV @ MLJ
RV-7 Coming Soon
N987RV Reserved
2015 Donation Gladly Paid
"Maintain Thy Airspeed, Lest the Earth Arise and Smite Thee"
Old 10-30-2011, 06:30 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Short answer...no.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 10-30-2011, 08:01 AM
jsharkey's Avatar
jsharkey jsharkey is offline
Glenn Wilkinson
If you mean the manufacture date that you declare to the FAA when you register the aircraft then you are the manufacturer so the date is when you finish and make it ready for registration. If you just want to know when the kits were shipped then I bet that Van's does have these records - a least for the past few (5-10) years. Whether they want to tell you or not is another matter.
Old 10-30-2011, 10:58 AM
bruceh's Avatar
bruceh bruceh is offline
Each of the kits I have received has had a variety of dates of manufacture. Some of the parts, like fiberglass, have an inspection tag with a date.
If you need a date, then use the invoice date.
Bruce Hill
2020 VAF donator
Old 10-30-2011, 06:24 PM
I was thinking in terms of the fuse since I've been told that is the only part of the airframe that is serial numbered.
Just curious...
Glenn Wilkinson
RV-4 Sold
N654RV @ MLJ
RV-7 Coming Soon
N987RV Reserved
Old 10-30-2011, 06:43 PM
Mel's Avatar
Mel Mel is offline
As far as I know, none of the RV kits are "serialized" (Except for the RV-12 when built as E-LSA). You are assigned a serial number of "plans", but you are not obligated to use that S/N.
In the beginning, the fuselage center section and wing spars were serialized because they were "match drilled", but that is no longer a factor, with the possible exception of the -3, -4 and -6.
You may assign any serial number to your aircraft as long as you have not used the same serial number on another aircraft.
The "official" date of manufacture of your airplane will be the date the airworthiness certificate is issued.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-30-2011, 07:44 PM
N941WR's Avatar
N941WR N941WR is offline
To add to Mel's post. When you buy a new kit (-7, -8, -9, or -10), you are giving your builder / serial number when you order your tail kit.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
