10-27-2011, 08:16 PM
Supersized elevator horn holes-what to do?
It was all going so well. Horiz stab, elevators. Then the time came to drill the holes in the elevator horns. After lining up the trailing edges, I got out the long #40 bit and drilled those holes with no guide between the horns.
Well, the holes are out of alignment. Putting the AN3 bolt will surely pull the elevators out of alignment. So, I started working the holes with a file in hopes of getting them from #40 up to 3/16. I pretty well got the alignment straightened out but, one of the holes is now an AN3-1/2. The elevator horn hole on one side is about 1/32 oversize. This just does not seem like the place to tolerate it.
I am considering stepping up to AN4 with a new $45 rod end from Spruce.
I have also thought about just putting an external lock washers on either side of the over-sized hole in hopes that it would prevent the 1/32 play in one of the elevators.
I am also looking for a good way to ensure that the elevators are lined up correctly.
I will never, ever freestyle drill again!!
Feedback appreciated......
Dave
10-27-2011, 08:49 PM
Weld it up....
Start over....
Carefully follow the instructions to be sure that the holes line up...
Dave & Trina
RV-9A Flying  - 330 Hrs. Painted  Finishing the interior.
10-28-2011, 05:55 AM
Swap the rod end and drill or file for an AN4 bore, or weld up the oversize hole and drill again....either is fine.
The lockwasher approach is unacceptable.
Dan Horton
RV-8 SS
Barrett IO-390
10-28-2011, 06:30 AM
Weld it
You arent the first to do that ! I have repaired 2 other horns with the same scenareo for fellow builders. It can be easily welded with the horn still on the elevator assembly. After its carefully ground down, you wont even be able to tell. Both of the aircraft I repaired have been flying for over 10 years with no problems. If the weld is allowed to cool slowly, there will be no side affects of hardening.
Bill E.
RV-4/N76WE
8A7 / Advance NC
10-28-2011, 01:28 PM
Weld it - that's what I had to do on our 8
Followed the instructions, drilled the correct horn but then realised that one horn was slightly twisted up relative to the other.........
This is our second, so I am a little embarrassed.
Anyhow, took it to my mate who glued the hole up with CMS32 rod, I fettled it back - you couldn't see the weld ! He is a very clever chap.
Redrilled - this time from the other side - no problem.
Hey Dan - That new Avatar looks a hoot !
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
10-28-2011, 02:01 PM
Originally Posted by MauiLvrs
Weld it up....
Start over....
I had to do the same thing.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
10-28-2011, 02:05 PM
Forum Peruser
The Mother Tongue
Mike,
How refreshing to learn some new word today. I did not know we could fettle back our elevator horns.
Seriously I did not know what fettle means until I read your post and then looked it up.
Thanks. Add another reason to read VAF every day. I hope to visit the Motherland someday.
Don Hull
Descendant of George Hull of Crewekerne, county Somerset, England who arrived in New England (Connecticut) in 1630.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
10-28-2011, 06:00 PM
An alternative approach might be to bolt a plate of 0.063 steel on the side of the horn (outside, cut the plate to fit closely within the horn flanges), drill it straight, then bolt another plate on the other horn and backdrill it.
greg
Greg Arehart
N 7965A
10-28-2011, 07:25 PM
Yup, weld it up and re-drill the horn. Even though the repaired hole surface will be harder because the welding rod material is harder,
it will drill easily with a sharp bit because the horn leg is so thin. My one horn was five bucks to weld up.
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
10-28-2011, 07:45 PM
drilling hole
Im fixing to take tail group off my project to paint when i take it off im going to put horz on saw horses with elv on horz and drill hole for push rod whats the trick or tool to get it straight.
bob
