Originally Posted by DEWATSON
Walt.....it does have ECI fuel injection.
Link to Manual
The AE fuel injection system requires the use of
at least one boost pump. The primary
requirement is that the boost pump must produce
between 18-22 psi fuel pressure for emergencies
if there is a loss of pressure from the engine
driven fuel pump. Similar fuel injection systems
used in certificated airplanes also employ a low
pressure fuel pump (3-5 psi) for take-off and
high altitude operation.
CAUTION
Excessive operation of the high boost pump
will cause the engine to flood. Operation with
low boost at intermediate power settings may
require the engine to be leaned slightly to
provide smooth operation.
AE recommends using low boost pressure for
take-off. Low boost can also smooth out engine
acceleration when the engine is cold.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Website:
ExpAircraft.com, Email:
walt@expaircraft.com, Cell: 972-746-5154
