10-25-2011, 01:18 PM
carry the spare
I had a flat in the hanger on Wednesday. No big deal. I had the other one go flat at the gas pump yesterday 800 air miles from home. Thank goodness some RV forum recommended that you carry a spare which I do. The FOB loaned me a jack. I pulled the tire, put in a tube and lost only an hour on a 6 hour x-country. In 1000 hours of flying I never had a flat until yesterday but it can ruin your 'hole' day so far from home. Thanks Forum for saving my bacon!!!!
John D. Artz, EAA 71811, 100+ Young Eagle flts
Adopted Dave's 6A
MXL Ultralight, only bleeding after 3 landings
Scorpion Two Helicopter, big mistake
PA-28 and 210E Centurion
10-25-2011, 03:41 PM
Wheels really are the weakest link in any airplane.
Doesn't matter how fastidious you are about maintenance, or how much you spend on reliability, or how careful you are with your flying, you can always be grounded by a flat tire.
- mark
[ Paid up on 3 Feb 2020 ]
RV-6 VH-SOL
10-25-2011, 06:13 PM
My backup plan
After having 3 main flats on our RV7a in the last 2 years, I now carry a spare main tube as well as a nose wheel tube in the baggage stuff. Two of the flats occurred on trips out of town and one occurred while landing at home. We do not leave home without our spare tubes.
Tom Lewis
RV7a N967BT 1900 hrs.
RV10 N143EB 960 hrs.
Granbury, Tx
http://bit.ly/2bnimsZ
11-08-2011, 03:56 PM
im having some fun with the nose wheel tube replacement.
any trick that you guys know of to not pinch the tube when assembling the rim halves?
11-08-2011, 04:26 PM
Some wood blocks and a couple of big c-clamps will do the trick.
I also carry a main and nose tube, would not leave home without them.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
11-08-2011, 04:56 PM
I cut a piece of thin cardboard or other thick paper about 2 inches wide and length equal to the rim circumfrence. I place the tube in the tire, place the tire on one rim side, place the paper / cardboard between the tube and rim, tuck the paper / cardboard inside the top of the tire, slide the top rim half down leaving the paper / cardboard inside the tire. Works great.
I have also found that flats occur more frequently when I allow air pressure to drop. Thus, I monitor tire pressure and maintain high pressure - never had a flat when I have maintained pressure. I believe lower pressure allows the tube to get pinched between the tire and rim upon landing.
11-08-2011, 05:01 PM
Green Slime
Been using this in my airplanes and motorcycles for years, never had a flat, never carried a spare even in the Backcountry.
Works great. Sold at the Wal Mart aviation dept.
Smokey
http://www.slime.com/
11-08-2011, 05:16 PM
I lightly (barely) inflate the tube inside the tire and then insert the wheel halves. Keeps the tube from being caught in the seam (it just rides over it)
-- Mike Culver;
RV-9 project sold  but details of the build at
www.mculver.com
11-08-2011, 05:57 PM
Smokey
Just out of curiosity, how are you going to change a tire on a bike? And how do you carry a spare?!?!
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
11-08-2011, 07:19 PM
I carry a main and nose wheel tire, one main tube and TWO nose tubes.
