Originally Posted by alpinelakespilot2000
In trying to reconcile this apparent contradiction, one of the main things I wonder is whether the torque for our soft aluminum tubing should be different from the perhaps harder materials used in Aeroquip hoses. )
Steve, you've hit a home run.
The torque values (inch pounds) Vans stipulate for aluminium AN-818 nuts being tightened
onto grade 6061 aluminium fittings are sourced from the Aeroquip Fittings Catalogue. -4 is 100/140 min/max and -6 is 150/195 min/max.
onto grade 5052 aluminium tubing (flared) are sourced from AC43.13. -4 is 50/65 min/max and -6 is 110/130 min/max.
Both are correct.
It is logical that the torques required for grade 5052 aluminium tube (flared) are considerably lower that the torques recommended for grade 6061 fittings because 5052 is a considerably softer alloy than 6061.
Many RV builders persist in wrenching up all AN-818 nuts on their flared aluminium tubing (fuel and brake lines) to the much higher torque values specified for 6061 fittings.
The end result is that the soft tubing flares are usually "creamed". In the particular case of the -4 aluminium brake lines this overtorquing is often the cause of sudden failure in service at the flare. This of course results in loss of braking on one wheel and has the potential to cause a serious brake fire.
The problem of overtorquing aluminium tubing in RVs is exacerbated by the fact that the grade 3003 tubing Vans supplies for fuel and brake lines is not in fact aviation grade. Compared to aviation grade 5052 aluminium tubing, 3003 tubing is considerably softer, and is .003" less in wall thickness. That makes it even more susceptible to damage from over torquing.
Of course needless to say Vans supplies the grade 3003 tubing because it is a general commercial grade and therefore much cheaper (surprise, surprise).
Hope I've been of assistance.
