Old 10-23-2011, 03:25 PM
cbrown747 cbrown747 is offline
Default garage size needed to build rv-10?
I am moving into a new home that has a garage size of 20 x 20 and ceilings of 9'. I know the rv-10 is 24' 5" completed but I would like to know how much of the building process I could complete in the garage before moving it to a hangar to attach the wings, etc..
Old 10-23-2011, 03:38 PM
kylecivicsi kylecivicsi is offline
a 20x20 building should be about 28.3' diagonally. It would be a really tight squeeze, but you have a shot of getting the whole fuselage in there.
Old 10-23-2011, 04:47 PM
rleffler's Avatar
rleffler rleffler is offline
I built mine in a standard two car garage. If you go to mykitlog site, you'll see how much other junk I had in my garage too. The first two years, I only used one bay, so the wife's car was inside during the winter.
I was about six inches too short to hang the engine in my garage. (again too much other stuff). However, I did have the RV-10 in the garage for the first 3.5 years of the build.
With the tailcone on, I could put it in aligned like a car, but there were only a few inches to spar. This made it difficult to work on during the winter. The last year or so, it was diagonal across the two bays so that I could walk around both sides.
It did require seasonal garage re-arrangements depending if I needed lawn or snow equipment easily available.
I know plenty of folks that completed their entire build in the garage.
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 10-23-2011, 05:41 PM
Pat Stewart Pat Stewart is offline
I built mine in a standard 2 car garage diagonally, it was tight but no problem.
Old 10-24-2011, 06:05 PM
thanks for the replies
