Old 10-23-2011, 09:38 AM
rapid_ascent rapid_ascent is offline
Default Empennage is done
Well I riveted the trailing edge of the rudder, installed the rudder tip rib, and I was done. On to the fiberglass and I need to get those wings on order. For some reason I was expecting confetti and horns with the last rivet. Still it feels good to be able to move on.
I'll have make an order to Aircraft Spruce for my glassing supplies. If anyone has any suggestion just let me know. I've read a bunch on previous threads so I think I know what's needed.
One thing I'm not sure about is if the tips are glued prior to being riveted? Seems like I saw that in one of the threads.
Off to clean more stuff out of the hangar, uh garage... Got to make room for those wings. Ho ho ho to me.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 10-23-2011, 10:14 AM
Mel's Avatar
Mel Mel is offline
If you are building a tail wheel airplane, I recommend that you delay installation of the bottom rudder fairing until you get it mounted on the fuselage with the tailspring in place.
Don't know of any reason to "glue" the tips in place.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-23-2011, 12:11 PM
6 Gun 6 Gun is offline
Default capping caps
i used some sheet scraps of .025 and 5 min epoxy to make my caps worked good and finished edges with micro and epoxy
Old 10-23-2011, 04:04 PM
Mel, thanks for the feedback. The upper rudder tip is on. I think the idea for glue was to make it stronger some how. It's a pretty tight fit so I'm not sure. The epoxy idea would have done much anyway.
One other thing as I was squeezing the tip it seemed like the joint opened slightly. Should I put a piece of cloth over the outside as I'm doing the glass work?
It's going to be a 7A but I'm not sure I'm ready to attach the lower rudder piece yet. I'll take a look at how the cutout has been done before I work on that one.
Ray Tonks
2020 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
Old 10-23-2011, 06:26 PM
Roy Thoma's Avatar
Roy Thoma Roy Thoma is offline
I had fiberglass help from a friend who has built 9 Lancair's, and a lovely 1950's fiberglass bodied Ferrari from scratch. I put a flox mixture on the flange of the fiberglass tips, which when riveted on squeezes out the seam between the skin and the tip. After curing, this is sanded flush, filling the seam. IF you plan to finish your plane so the seam is hidden, this is easier than trying to get filler to stay in the joint.
Regards,
Roy
N174RT (RV-7A) first flight 5/31/11, 1780hrs as of August 2020:
Tip-up, Lycon IO-360 EXP, WW 74HRT, AFS 5600T, AF-Pilot, IFD440, SL-30, echoUAT, D100 for backup, CQ1 headsets, CMW E-Lift
Our other riveted aluminum monocoque RV is a 25' Airstream
Past aluminum monocoque vehicles:
N601RT (CH601HDS) First flight 5/03, 1550hrs after flying 8 years: 912ULS, GNS430W, SL-30, D10A Sold
1995 Midnight Pearl NSX w/BBSC Sold
EAA Chapter 105 board member 2010->2015
