Go Back   VAF Forums > Model Specific > RV-4
  #11
Old 10-23-2011, 08:26 PM
nauga nauga is offline
Originally Posted by nauga View Post
I'm about to walk out to the shop and see if I can get a few clear pictures of how I dealt with it.
Excuse the trash, I'm drilling new wiring runs.
Is this what you're looking for (minus the FOD )?
Left side, F404 at the bottom:
Right side, F404 at the bottom:
I ground back the vertical web of the longeron to clear the 404 doubler, but not very much. I seem to recall getting advice to do so from Vans, but that would've been years ago. I'll check my log.
Nauga
2004 RV-4
Old 10-24-2011, 02:34 AM
WAM120RV WAM120RV is offline
Wink Correct
Hi
I can confirm Nauga has built it as per plans, I checked mine last night and the plans show the F450 behind the U and the F405 (the dashed line) is the 450 hidden behind the other parts.
Not sure if you know this and not wanting to teach anyone to suck eggs but solid lines are thins on top...... dashed lines things hidden behind other parts.
Another point all this is hidden by the wing root so cannot be seen anyway.
Nauga has done a good job!
Old 10-24-2011, 08:27 AM
WSBuilder WSBuilder is offline
Default I agree
Originally Posted by WAM120RV View Post
Hi
Without a doubt, I would have the most confidence in Nauga's installation. It is definitely the best approach from a structural standpoint. And as you point out WAM, the skin transition over this assembly is hidden. I may install some shims to ease the skin transition so as to inhibit potential skin cracks.
I would add this specific issue on my list of things to look at when shopping for a used -4.
Bill Grant, A&P
8KCAB, M20G
RV-4: Fuselage controls
