10-21-2011, 12:49 PM
Hot Lycoming Restart
Who knows the fool proof way to restart a hot IO Lycoming? I can do it every time after a fashion but I hate grind the **** out of the starter and even my new battery often starts to loose some enthusiasm for the task just before it fires.
John D. Artz, EAA 71811, 100+ Young Eagle flts
Adopted Dave's 6A
MXL Ultralight, only bleeding after 3 landings
Scorpion Two Helicopter, big mistake
PA-28 and 210E Centurion
10-21-2011, 12:51 PM
Senior Curmudgeon
What kind of fuel injection do you have?
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
you will find many threads on the hot start issue using the search function.
Hit the search function, advanced search, searchtitles only, and put hot start in the terms. You will see lots of good info in there.
Kahuna
6A, S8 ,
Gold Hill, NC25
10-21-2011, 01:00 PM
I start mine the same - hot or cold. I have an IO-360A1A with bendix and show of sparks mags (bendix) - your mileage may vary.
Everything full forward - prime for 3-4 seconds
Throttle cracked, mixture ICO
Went it starts to catch, ease the mix to rich
Good luck finding your combination. If you are having issues, you might check your timing and all the ignition components.
10-21-2011, 01:32 PM
Fine wire plugs seem to me my hot starts.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
10-21-2011, 01:50 PM
thanks
Thanks Kahuna. I never tried the advanced search. It seems many have the throttle wide open on the prime. I always have is 1/4 open.
Adopted Dave's 6A
10-21-2011, 02:18 PM
My method that works for me
boost pump off
Throttle open 1/4"
mags on
crank
When it catches, full rich. I have found that waiting until the engine starts to die, then full rich, works better for me.
If the idle is rough, boost pump on.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
10-21-2011, 02:43 PM
An important point, in some of the above, I have recently found with an Extra 300 (IO-540) that has started having hot start issues (and not just with me!):
and
We found a broken spring in the impulse, and now seems better, but I did learn the "slowly" mix to rich, not ram it forward when it fires which seems to kill it
Andy
RV-8 G-HILZ
RV8tors
10-21-2011, 03:05 PM
FI hot starts..
FI Hot starts are premised on the engine is already flooded due to fuel vaporization while setting.
The secret is to treat it first as flooded, therefore:
Mixture at Idle cutoff,
Fuel pp ON
Throttle wide open
Ignition ON
Crank until it fires ( won't take but a few blades)
Mixture RICH and Throttle OUT (be fast about it)
If it won't fire, assume NOT flooded, then push Mixture in just enough to give it some fuel.
Works without fail Honest!
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
10-21-2011, 03:14 PM
Kinda what Mike says works for me. Generally the engine will be flooded prior to start.
Mixture ICO
Throttle 1/4-1/2 open
As it catches, push the mixture rich.
If this doesn't work after two tries, then flood the engine by mixture rich, throttle full, boost pump on for a few seconds. Then start as above. Purposefully flooding the engine before starting also works if you have sat for, say, an hour or so and are unsure whether the engine should be hot or cold started.
YMMV,
greg
Greg Arehart
N 7965A
