Old 10-20-2011, 11:53 AM
patterson patterson is offline
Default selecting the right carburetor
Hello,
I was hoping to get some direction from the group on whcih MA4 would be
rich enough to give my hybrid O-320 enough gas at takeoff and climb to keep the EGTs low and insure adequate fuel flow?
My new motor is an angle valve O-320 and will deliver 190+ hp....if I can get enough gas to it at sea level and initial climb. I have a 320 now with a reemed jet that helps, but I anticipate needing a carb with larger "internals" that allow for more flow even before gas gets to the jet. IS there such an animal?
Ron
RV-4 N8ZD
Old 10-21-2011, 02:05 AM
AK4x4's Avatar
AK4x4 AK4x4 is offline
Default Carb
I would think an MA-4-5 for a O-360 would be a good bet. Might need O-360 sump also for correct mount flange/hole size. Good Luck,Russ
Russell Brown
A&P/IA
"Happiness may never be sensibly pursued as an end in itself, because happiness is the by-product of achievement." -- Northcote Parkinson (paraphrase)
Wasilla, Alaska
