Old 10-20-2011, 08:39 AM
T.O.Craig T.O.Craig is offline
Smile edge protection
Good Morning to all,
I'm currently running some wiring in my fuselage and I am looking for some additional wire protection in certain areas. The material is a plastic edge protection that you can cut it to any length and it will slide over the edge you want to protect. I'm looking in the usual places but can't seem to find it ...
Thanks, Craig
Craig Rufi
FLYING NOW AFTER 13+ YEARS. NICE FLYING AIRCRAFT!!
RV-10/Empennage/Wings/QB Fuselage/Wiring/Doors done finally, Cowling done. Stein panel complete, and connecting all those wires :-))Thousand Oaks, Ca. Dues paid for 2019
Old 10-20-2011, 09:26 AM
TX7A TX7A is offline
Search 'Grommet Edging' or 'Grommet Strip' at Mouser or Digikey.
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 10-20-2011, 09:28 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
http://www.esterline.com/Portals/8/N...catgrom_07.pdf
Also, http://www.bonaero.com/ click inventory, then electrical, and scroll down.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 10-20-2011, 10:17 AM
wjnmd wjnmd is offline
I have some that I bought from Avery Tools. Not sure if they still sell it but you might try them.
Bill Near
RV-7A Flying
Old 10-20-2011, 10:35 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Aircraft Spruce has it...
http://www.aircraftspruce.com/catalo...mmetedging.php
This expensive Mil-Spec (22529) stuff grips better and will protect much tighter corners - both inside and outside corners - than the push on plastic stuff.
Note that a lot of the commercial stuff may not be made to grip on our 0.025 thick structure...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-20-2011, 10:45 AM
Mike S's Avatar
Senior Curmudgeon
What Gil says is correct, but I found a small dab of Shoe Goo and a bit of masking tape to hold it in place till the SG dried worked just fine.
For a round hole, just cut it long enough to fully fill the hole, and it will hold itself in place.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 10-20-2011, 10:49 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Avery has it: http://www.averytools.com/prodinfo.asp?number=21266
They don't show a photo for it, but it's the right stuff you're looking for, I've bought it from them a couple times myself.
(offtopic) BTW, they've got VAF hats on sale right now for $10 (hint hint)
http://www.averytools.com/prodinfo.asp?number=HAT-WISH
Neal Howard
Airplaneless once again...
Old 10-21-2011, 08:38 AM
Thank you all for your rapid response. Material is on order. Isn't this a great web site. Thank you all!
Craig Rufi
Old 10-21-2011, 09:46 AM
Mike S's Avatar
Senior Curmudgeon
Yep, sure is
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 10-21-2011, 10:03 AM
rocketbob's Avatar
In my 1966 C150, with 7000+ hours, imagine my horror when I was changing a landing light and noticed all the wing wiring passed thru rib holes with thin metal grommets stamped into the ribs. To my surprise I found there was no wear in the wiring. So don't over think this....
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
