Go Back   VAF Forums > Main > Safety
View Poll Results: Have you ever caught a problem during pre-flight?
Nope, never found any issues. 20 6.21%
Yes, only minor issues 134 41.61%
Yes, and once was an issue that could have cause major problems. 89 27.64%
Yes, and more than once I have caught major issues. 79 24.53%
Voters: 322. You may not vote on this poll
Old 10-19-2011, 09:58 AM
Phlyan Pan Phlyan Pan is offline
Default Have you ever caught a problem during preflight?
So I was doing preflight this morning before going up for some spin training (non RV but forgive me) and I got to thinking...I wonder how often people catch problems during preflight. I'm just wondering what the hit rate is...not really trying to push any kind of agenda, just curious.
Just to be clear, I'm only talking about during the walk-around portion...not run up and control checks and stuff.
Old 10-19-2011, 10:12 AM
krw5927 krw5927 is offline
Not an RV, but my preflight on the skyhogs I fly always includes a gentle up-down wiggle of the horizontal stabilizer near the root, on each side of the aircraft. I noticed some "squishiness" when squeezing the rib nearest the fuselage to give it a wiggle, which prompted further investigation. One of the bottom rib-to-skin rivets was smoking and could turn in its hole, so I grounded the aircraft.
Good thing, too, because upon disassembly the A&P found the horizontal stabilizer rib was completely cracked through. To date still not sure how it happened or how long it had been flying that way. Oh, and note the lack of primer on a certified aircraft that's over 30 years old
Kurt W.
RV9A
FLYING!!!
Old 10-19-2011, 10:24 AM
Bill Wightman's Avatar
Bill Wightman Bill Wightman is offline
1. C152 with a loose horizontal stabilizer
2. Propeller delamination on my RV4
3. B737-300 with bent fan blades
4. B767-300 with a major strut leak in main gear
?The important thing in aeroplanes is that they shall be speedy.?
- Baron Manfred von Richthofen
RV8 under construction
RV4 - Sold
United B777 FO, Chicago
Aero Engineer
RV8
Old 10-19-2011, 10:26 AM
WSBuilder WSBuilder is offline
Default Yes!
Over the years I've found low tires, bird nests, bugs/spider webs in vents/pitots, loose gas caps and (most embarassing) missing access covers following (my) maintenance. Just like the flying part; hundreds of boring inspections punctuated by terrifying discoveries.
Bill Grant, A&P
8KCAB, M20G
RV-4: Fuselage controls
Old 10-19-2011, 10:35 AM
Cadstat's Avatar
Cadstat Cadstat is offline
Default INSPECTION
I turned up a missing cotter pin once in a very important place. I was told to look for birds nests and it took over thirty years of flying to finally find one but it made all those pre-flights worth while. Collapsed nose strut bottom out but that was an easy one. I test the brakes too before even looking at the check list once inside and have had one of the pedals go to the floor on occasion.
John D. Artz, EAA 71811, 100+ Young Eagle flts
Adopted Dave's 6A
MXL Ultralight, only bleeding after 3 landings
Scorpion Two Helicopter, big mistake
PA-28 and 210E Centurion
Old 10-19-2011, 10:37 AM
apkp777's Avatar
apkp777 apkp777 is offline
I force myself to walk around just to make sure I disconnected my tow bar.
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 10-19-2011, 10:39 AM
Bob'sRV6A Bob'sRV6A is offline
T28--smashed elevator (by forklift)
H46--missing cotter pins in newly installed control arms to rotors
H46--milky transmission fluid in sight hole (analysis showed that someone poured milk into fluid)
H46--hand grenade with pin pulled in empty peanut butter jar under passenger seat
Bob Marshall
Old 10-19-2011, 10:43 AM
johnfurey johnfurey is offline
NO, But I have 1st hand knowledge of 2 dead stick landings in 2 different airplanes that would never have happened if a proper preflight had been done Name and details witheld to protect the guilty
John Furey, RV7. Ohio
Life's Short...Fly Often!
Old 10-19-2011, 10:50 AM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Originally Posted by Bob'sRV6A View Post
. . .H46--hand grenade with pin pulled in empty peanut butter jar under passenger seat
Now that is a find that must have a story behind it!
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 10-19-2011, 11:02 AM
Cadstat's Avatar
Default Check the oil
Our flying club in college washed the planes every Sat morning. Someone would take it around the pattern to partially dry them and then towel completely. Only problem was the 150 was in for an oil change and in haste to build a few minutes of free flight time a student pilot didn't check the oil or the oil pressure gauge. He made pattern alt downwind without any oil then 'landed' (sank) in a lake and survived but good bye Cessna 150.
Adopted Dave's 6A
