Have you read through the documents on the CAFE web site?
http://cafefoundation.org/v2/tech_lib.php
IIRC, there are some comments about the technique making significant improvements at low speeds & high power but actually increasing drag at altitude & cruise speeds, apparently due to pumping excess air through the cooling system at speed.
At SNF about 10 years ago, Tracy Saylor (sp?) of RV-6 fame once told me about working on tuning his exhaust length, & said that each time he cut off a bit of exhaust pipe length, he got a bit more power. He said that he was fearful to make the 'next cut', which would put the ends of the pipes inside the cowl, in front of the plane of the firewall. He decided to go ahead & try it, and when he did, power again went up and coincidentally, his slightly high oil temps actually came down. He also mentioned having cooling guide vanes below his cylinders, so he probably created an augmenter when he made that next cut.
Charlie
