Old 10-17-2011, 01:56 PM
jdeas's Avatar
jdeas jdeas is offline
Default Alternate air sources FI
I am currently building a vertical induction FI (Bendix). The plans call for both a heated air door at the front of the air intake and an emergency air door mounted to the bottom of the filter box.
I fly behind an O-360 where this makes sense to me but are they both needed for an FI system?
What additional risk would I be taking if I just installed the 'emergency' unfiltered air door on a FI system?
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
Old 10-17-2011, 02:27 PM
flyinga flyinga is offline
I never heard of heated air for a FI engine. With no venturi ice is most likely to form on the filter. I'd go with the alternate air door only.
Old 10-17-2011, 08:34 PM
flion's Avatar
flion flion is offline
That's correct. Leave the heated air flapper off. If you use Van's alternate air kit, make a reinforcing ring to sandwich the fiberglass bowl with the inlet ring. Just riveting the ring to the bowl will see the rivets pulling through in short order.
EAA Technical Counselor #5357
