Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 10-16-2011, 01:20 PM
TX7A TX7A is offline
Default Shielded wire for GPS signal?
I'm wiring in a source select switch for GPS to A/P. Do the signal wires from GPS (lets say a 496) need to be shielded?
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 10-16-2011, 02:18 PM
rleffler's Avatar
rleffler rleffler is offline
All RS-232 and RS-422 lines should be shielded. Be sure only to ground the shield at one end and don't use the shield for a signal line.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 10-16-2011, 02:55 PM
Walt's Avatar
Walt Walt is offline
I agree they "should" be, but with such short runs usually found behind the typical RV panel, I really don't think its necessary. I have seen and run many single wire RS232 lines in RV's, never had a problem.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 10-16-2011, 03:09 PM
rv9aviator rv9aviator is offline
Mine isn't but it is only about 10 inches long. Could that cause any kind of noise in the audio?
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 10-16-2011, 06:53 PM
Wayne Gillispie Wayne Gillispie is offline
None of mine are shielded. I will let you know how it works out soon.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 10-17-2011, 04:31 AM
rleffler's Avatar
Probably not, unless your audio lines are unshielded. RS-232 isn't used for audio. What would have a greater potential to add noise is ground loops. I would refer you to Bob Nuckolls book for more information. He may also have a white paper on his web site.
bob
Bob Leffler
Old 10-17-2011, 08:27 AM
Question One more thing...
Thanks, Bob & Walt.
I'm seeing three wires that need to be switched (does not include the shield): ARINC A, ARINC B & RS232
Does that sound right?
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 10-17-2011, 08:43 AM
rleffler's Avatar
Thanks, Bob & Walt.
Hard to guess without a schematic, but looks to be correct. Also look at your audio lines.
Bob Leffler
