Old 10-15-2011, 12:31 PM
Darren S Darren S is offline
Default Here's a challenge for you...
I live about 5 miles from my hanger. Winter is cominng and I need to preheat my engine. I don't have AC power at the hanger so I use a generator to power the Reiff pre-heater.
I want to be able to use my cellphone to start my generator. Some guys on the web have rigged a way to start their cars using a cellphone but in thought I'd tap into the vast knowledge of VAF before I start jacking with stuff.
I am willing to get an electric start generator rather than the pull start I currently have.
Let me know if anyone has some ideas.
Darren
Old 10-15-2011, 12:39 PM
rocketbob's Avatar
Does the FBO at your airport have internet/wifi?
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 10-15-2011, 12:52 PM
DanWright DanWright is offline
If nothing easy comes forward, check out home automation forums.
Dan Wright
Building RV-12 #511 in the Mojave desert (1976W reserved)
Old 10-15-2011, 01:39 PM
No wifi at the field. Just 3G when I have to use the Internet to check weather.
Will check home automation sites. Thanks for that.
The car starter guy used a cheap remote car starter and a hijacked $10 cellphone.
Where there is a will....there is a way
Darren
Old 10-15-2011, 01:49 PM
TruTrakAndrew's Avatar
TruTrakAndrew TruTrakAndrew is offline
Default Hmmmmm
I remember seeing something on the front page...www.dial2start.com I think. Maybe that's what you are after?
Just re-read your original post... DUH!!! You said no a/c power!!!
Andrew Barker
BendixKing
TruTrak
RV-4 214NY "Carrie Ann"
RV-10 989TS
Always flying someone else's airplane too
EAA - 309420
Old 10-15-2011, 02:15 PM
Bevan Bevan is offline
Where is the generator? In the hangar? If so you need to be mindful of the possible hazards. Possible build up of fumes. Possible fire hazard of unattended portable generator. I'm thinking someone puts a coat or something onto the generator and forgets/doesn't know it can auto start. Someone nearby is cleaning with flammables, and not expecting an automatic ignition source. How would you turn it off if plans changed and you couldn't make it to the airport? etc etc.
I'm wondering if a 12V car battery connected to an inverter connected to the heater and switched on by the cellphone would be better?
Just thinking out load here.
Bevan
Old 10-15-2011, 02:43 PM
AltonD's Avatar
AltonD AltonD is offline
50 amp discharge from the car battery. It would not last long.
I would also worry about the remote start generator being unattended.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 10-15-2011, 03:16 PM
I am the only one in my hanger so there wouldn't be anyone else monkeying around in there ie. leaving a jacket on the generator.
I also have an exhaust tube connected so that the generator fumes exhaust to the outside.
I usually run out to the hanger in the wee hours in my Pj's, start the generator, hook up the pre- heater and then come back home to drop kids to school etc... I'll return 2-3 hours later and by then the oil temp is up to 100+ degrees. Good to go.
I don't feel I'm being unsafe by leaving the generator running unattended. I did it all last year. I'm just looking for a way to avoid the Pj run
I like the idea of the 12V battery with the inverter but I don't know how long it would last, plus how long it would take the solar charger to re- charge it.
Would 4 car batteries in parallel last 3 hours on the pre-heater?
Thanks for the ideas though. I'm still digging.
Darren
Old 10-15-2011, 08:21 PM
Looks like my grand idea won't work. With the electric start generators the choke still has to be operated manually which defeats the whole purpose. No such thing as a fuel injected generator with electronic ignition
Rats! Oh well.
Old 10-15-2011, 11:32 PM
Darren,
How much power does the pre-heater draw? The inverter system would be very inefficient so double the number (at least). If that leaves you in the ball park for your battery, give it a try.
I bet there is a way to do this safely.
Bevan
