Just test flew my newly designed Craig Catto 2 Blade composite prop, woo hoo! Removed my MT fixed pitch from the RVX to test this new design for Craig and give good comparison data. But I digress...
Way back in 1998 I was flying my 150HP RV4 in CA with a Sterba WP when a local at a fly-in asked if I liked the wood prop. I did, but wanted something a bit different and more modern. He said I needed to meet a crazy local prop maker who made composite props for Long-EZ's and Reno racers. Little did I know after shoe-horning my RV4 into Craig's mountainside airstrip, visiting his shop and carrying away a loaner test prop I was starting a lifelong friendship. The 2 blade I bolted on my RV4 was Craig's first RV4 installation and first 2 blade RV prop. It would be the first of many props I would test and fly for over 10 years. OK, back to the future:
Aircraft: Modified RV-6X (RV4 wings and emp, RV6 fuse 150HP 945 lbs EW)Fairings cleanup and rigging by
Ronnie.
Comparison MT 69" Fixed Pitch scimitar composite 175R-180S-3Ea (custom designed in Germany) vs Catto 70X69 Composite scimitar 2 blade.
Test conducted at my home strip 90' MSL 85F 1800' long Turf.
MT:
Static: 2150
Takeoff/Initial climb 80 Knots 2300 1200 FPM
100 Knot climb 2375 RPM 1500 FPM
120 Knot climb 2440 RPM 1600 FPM
WOT 1000' MSL 2675 RPM 172 KIAS
WOT 5000' MSL 2660 RPM 158 KIAS
WOT 8000' MSL 2600 RPM 148 KIAS
WOT 10000' MSL 2550 RPM 141 KIAS (170 TAS)
New Catto:
Static 1950
Takeoff/Initial climb 80 Knots 2155 1200 FPM
100 Knot climb 2250 RPM 1400 FPM
120 Knot climb 2440 RPM 1900 FPM
WOT 1000' MSL 2875 181 KIAS
WOT 5000' MSL 2810 164 KIAS
WOT 8000' MSL 2775 156 KIAS
WOT 10000' MSL 2700 150 KIAS
Overall, the Catto really wakes up at 120 knots and is like all his props, turbine smooth. It works better at higher altitude than the MT and out climbs it in the lower altitudes. The MT shines in lower RPM, lower speed operations. The Catto fit, finish and new Nickel leading edge are an out of the park home run. And like everything Craig does and himself included, a class act.
Highly Recommended
Smokey
