Garmin 327 wiring question
I am wiring the 12v power to my Garmin 327 transponder from an avionics bus that takes power from the main bus through the avionics switch. That 12v power goes to pin 15 on the 327 connector.
I notice that the Garmin 327 pin 1 is supposed to connect to the avionics master switch, hot side.
I have three choices:
1) Do not connect pin 1.
In which case power will come to the 327 into pin 15 when the unit is turned on. That power will generate when the avionics switch is in the on position.
2) Connect pin 1 on the 327 to the hot side of the avionics switch.
3) Connect pin 1 on the 327 to the same terminal on the avionics fuseblock, which seems to be electrically the same as 2) above.
I am not sure what the function of the pin one input is. Can anyone shed light on this question?
Tony Johnson
RV8A "Badboy" N12TJ
Treasure Island Florida
