Old 10-11-2011, 01:59 PM
cstanley cstanley is offline
Default Nuts over Nutplates
I am working on my tunnel, and am having real difficulties getting the screws into the nutplates. The screws are so tight that I am tearing up the heads trying to get them in. The room is so limited in the tunnel that I have to use a shorty driver, and that doesn't help. Yes, screws and nutplates are correctly sized.
Is there some secret or technique that will help?
Chris Stanley
Builder No. 40599
RV-10 SB - Emp complete, wings complete, fuse underway
Old 10-11-2011, 02:04 PM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Default A couple of suggestions..
When I installed my Duckworks lights in the wings of my RV-4 the instructions said to add some grease to the screw the first time it was installed in the nut plate. Otherwise the screw might break off. I now do this on the first insertion on a new nut plate.
Also, if you are working with Philips screws, put a tad of valve grinding compound on the screwdriver tip. It will securely grab the screw and you'll have little chance of stripping the head. I use valve grinding compound whenever I remove or install Philips screws and have not stripped one using that technic.
YMMV, hope this helps.
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 10-11-2011, 02:05 PM
Mark Albery's Avatar
Mark Albery Mark Albery is online now
Running a tap through them usually works.
Old 10-11-2011, 02:30 PM
jchang10 jchang10 is offline
I used Boelube on all my internal screws, and anti-sieze on all my external screws into nutplates.
If the heads are bad going in, getting them out can be dicey if it can be done at all.
#40533 RV-10 Builder and CFI
1/2006 Started build
10/19/2011 First flight
Old 10-11-2011, 02:43 PM
JonJay's Avatar
JonJay JonJay is offline
This defeats the self locking properties of the nutplate. Be carefull.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 10-11-2011, 03:32 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
For the tunnel area, dump the phillips head screws and get some allen/socket head screws. Put an socket bit in your socket wrench. The socket wrench fits much better than a screwdriver here. Your problem should then be solved. My opinion is to not tap nutplates, especially if they are for a structural connection, but Boelube works well to loosen things up.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 10-11-2011, 03:37 PM
jdeas's Avatar
jdeas jdeas is offline
Default Try a different head
I replaced all my small tunnel hardware with hex head screws. Used a socket wrench as well to avoid any possible scratches to the surface around the screw.
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
Old 10-11-2011, 03:53 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Default 90 degree ratchet phillips screwdriver from Harbor Freight
I found this little tool invaluable for getting at philips screws in tight spots.
http://www.harborfreight.com/hand-to...ver-92630.html
And since it uses ordinary 1/4" hex-drive bits, you can make custom-length shorter bits if needed, by sawing them down with a cutoff wheel.
Neal Howard
Airplaneless once again...
Old 10-11-2011, 05:03 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
You can loosen up the threads with a tap-----but be sure to not run it all the way in.
I use bees wax for a lube in nutplates, I use a toilet sealing ring as my source of bees wax, and a tooth pick to insert a small dab inside the nutplate.
Two cautions for you-------one, resist the urge to use a cordless drill to run in the screws fast-------if you are using a cordless run it slowly. And that goes double if you are using stainless steel screws. And the second, dont use stainless screws if you dont need to-----or at least run a standard steel screw in first, then the stainless after the nutplate is broken in a bit.
Good tool shown above also, I use one made by Husky, has a 1/4" hex end, and a 5/16" hex on the other end which drives an adapter to a 1/4" socket driver.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 10-12-2011, 08:02 AM
woodmanrog's Avatar
woodmanrog woodmanrog is offline
Ditto with the thread Mike just posted. The wax method works best for all lube needs including inserting cowl and fairing pins. DO NOT retap nutplates as you defeat the self locking purpose. The screws will vibrate loose if you do this.
Woodman
