Old 10-11-2011, 01:37 PM
704CH's Avatar
704CH 704CH is offline
Default 4 pipe vs. crossover smoking?
I am wondering if there is a difference in smoke capability based on exhaust type. For example in the Pic that was used for the July Calendar. Is it possible that the RV on the top was a 4 pipe due to the more ?puff? like smoke from the ?single cylinder per pipe? ?
Just curious..
I am not necessarily talking about the pipes they smoke down there in California.. ;-)
Chad
Sammamish, WA
RV-7 Standard Build - Tip UP
Flying ! As of 032913
Superior IO-375, WW200RV, Single Lightspeed, SkyView, GTN
http://www.704ch.com/
Old 10-11-2011, 03:56 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
One injector in a four pipe system should put out 1/4 of the smoke of one injector is each of a two pipe system. Unless my thinking is wrong of course.
Old 10-11-2011, 04:29 PM
cplunkett cplunkett is offline
Chad, I am that guy in the photo "puffing". Team RV was performing in the "PDK Good Neighbor Day" Air Show. When I saw myself on the debrief video, I knew I had a problem. It was a plugged smoke injector. I have a "four into two" exhaust system with one injector in each stack about 6 inches from the exhaust exit. Works well when the injectors are clear :-)
"Bones"
Team RV Airshows
Old 10-11-2011, 04:30 PM
Tony Spicer Tony Spicer is offline
That would be Charlie 'Bones' Plunkett doing his impersonation of the Geico Skytypers. It's morse code that says "Enough already, Kahua"!
One clogged injector looks very similiar.
Tony
Old 10-11-2011, 04:32 PM
jrs14855 jrs14855 is offline
Default smoke
two injectors in a crossover puts out a lot of smoke. Approximately 4 gallons used in 12 minutes. I had the injectors fairly close to the cylinders, can't remember the exact distance.I think the injectors were in the two rear cylinders, its been 20 years.
Old 10-11-2011, 07:15 PM
Ron Lee's Avatar
Bones, that is still a very impressive picture. Great flying.
