QB tank leaks
I too have QB tanks and within 6mo. of putting fuel in them, both leak around rivets such that I have many paint blisters. All blisters are dry, I have no wet leaks. Boroscoping the tanks shows pretty significant lack of proseal over rivet heads. I've had numerous discussions with Vans and they have provided all repair materials at no cost. However, that doesn't negate the poor workmanship that is occurring in QB tank construction. I think all QB tanks should internally inspected for quality application of Proseal. I also think all QB tank external rivet heads should be treated externally with Lock-tite 290 wicking formula as a precaution.
I've not yet repaired my tanks, it's a project for this winter. Because I have no liquid leaks, my plan is to remove all paint along the rivet lines, aggressively abraid the surfaces with sandpaper and scotchbright. All rivet lines will be filled with epoxy & microballoons, apply a fiberglass tape over that, then micro balloons over the glass tape.
To attempt to repair from the inside would require cutting large holes in the rear tank wall between each rib (6holes per tank). It would require difficult cleaning and even more difficult to apply more proseal through the rear baffle holes. I fear the cure could be worse than the disease.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
