Old 10-06-2011, 12:43 PM
Flying Scotsman Flying Scotsman is offline
Default Control cable attach to Alt Air door
I am using McFarlane push-pull cables for things like oil cooler shutter, cabin heat and (the question at hand) the alternate air door.
These cables have a fairly thick (I think it's .093") inner cable.
Stock instructions for attaching to the alternate air door have you wrapping the cable around the #8 screw and cinching down with a washer and nut.
The inner surface of the door has to be flat, obviously, which necessitates a flat-head screw (or equivalent).
Anybody have a better method for attaching the cable? The thick inner cable *is* bendable, but my tests end up with a relatively unattractive (although serviceable) loop of wire.
N.B. The whole alternate air door assembly is already built, so I'm not looking for alternative solutions to the door. Neither am I interested in *not* having an alternate air source. Just a different way of attaching the cable to the screw (or a different sort of "screw" to attach to).
I thought of drilling a hole in the screw itself...not sure if that's a viable option or not.
TIA...
Steve
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 10-06-2011, 12:51 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Bug nut is the answer you are looking for.
Here is one example.
http://store.wagaero.com/product_inf...oducts_id=2297
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 10-06-2011, 12:59 PM
And which part is supposed to go on the inside of the door, which *must* be flush?
Santa Clarita, CA
#8,000
Old 10-06-2011, 01:04 PM
Mike S's Avatar
Senior Curmudgeon
Without seeing your setup, kinda hard to answer.
You may have to attach a small piece of angle to the door, and use that as an attach point for the bug nut and cable.
Mike Starkey
VAF 909
Rv-10, N210LM.
