Make sure you do cut the angled portion from the lower cowl. If you don't, when you try to remove the lower cowl after the airplane is completed, you will scratch the spinner. Next time you see "New Blue" at a fly in, take a look at her spinner. It has some scratches from this.
Mitchell Lock
President Van's Aircraft
