Old 10-04-2011, 02:27 PM
Flying Scotsman Flying Scotsman is offline
Default Adel clamp - changing "direction"?
Maybe I'm missing the forest for the trees, but does anyone have a clever method for "turning" the direction that two Adel clamps run? I.e., one Adel clamp on, say, a motor mount tube, and I need the second one to have its direction 90 degrees to the first (e.g., one on the tube going fore-aft, second one attached so cables/wires run left-to-right).
There's probably a dirt simple solution here (the engine wiring harness came with several metal "tabs" that accomplished this, but not enough).
TIA...
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 10-04-2011, 02:36 PM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Adel
Steve,
Just rotate one clamp 90 degrees. It's easiest if they are back to back (flat side to flat side). Sorry, no picture.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 10-04-2011, 02:45 PM
That will rotate the direction in one axis, but not the one I need...that will put them parallel (in one plane). I need them perpendicular.
Just imagine a tube with an Adel clamp on it:
_
_____________| |____________________
|_|
I now need to "twist" the direction of the second clamp to run "up and down" as seen here.
Santa Clarita, CA
#8,000
Old 10-04-2011, 03:21 PM
UnPossible's Avatar
UnPossible UnPossible is offline
I've just cut some short pieces of 063 angle and drilled holes on each face for the Adel clamps... seems to have worked pretty well for me.
Hope this helps,
Jason
Jason Tremble
RV-7A (Flying and Sold)
RV-10 in process (@#$$%# Cabin Top & Doors)
Paid for 2020
Old 10-04-2011, 03:26 PM
kentb's Avatar
kentb kentb is offline
Default Hi Steve.
What Don was trying to explain creates a 90 degree change in direction.
I'll try the ASCII picture to help.
engine mount adel clamp
_____________| |____|________________
.....................| |___ |
.....................|_|___|..| <- second adel clamp at 90 degrees
...............................wire
................................going
................................down through second adel clamp.
Another posiblity is to use a short (2 inches) piece of AL and twist it 90 degrees. Drill a hold in each end and attach the two adel clamps to it.
Hope this is readable and helps.
I found a picture. You can disregard the previous 1000 words.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 10-04-2011, 03:28 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Twist the first clamp 90* on the tube, so the flat is in the same plane as where you want the axis of the second clamp.
Then back-to-back a second clamp, and it will be where you want.
It makes more sense if you start with the second clamp, and then add the clamp that is going to anchor to the motor mount tube.
You can do this.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 10-04-2011, 04:09 PM
Not the best picture but you get the idea Piece of angle with two holes in it.
Old 10-04-2011, 04:43 PM
Toobuilder's Avatar
Not the best picture but you get the idea Piece of angle with two holes in it...
Picture in post #5 does the exact same thing, but no "extra" hardware.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 10-04-2011, 04:49 PM
In my case only that extra hardware worked. I tried post #5 trick in other spot.
Old 10-04-2011, 05:01 PM
DOH! Of course...that's what I get for trying to visualize it in my head at my desk instead of in front of the plane... LOL!
Thanks all...sorry for being dense .
Steve
Santa Clarita, CA
#8,000
