Old 10-03-2011, 11:26 AM
Cadstat's Avatar
Cadstat Cadstat is offline
Default any engine gurus out there?
I've heard you can turn a 320 into a 360 because the crank and cases are the same. You need a new cam and heads I've been told. Is this true?
John D. Artz, EAA 71811, 100+ Young Eagle flts
Adopted Dave's 6A
MXL Ultralight, only bleeding after 3 landings
Scorpion Two Helicopter, big mistake
PA-28 and 210E Centurion
Old 10-03-2011, 11:35 AM
rocketbob's Avatar
You heard wrong, can't be done. Stroke is different.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 10-03-2011, 11:38 AM
osxuser's Avatar
osxuser osxuser is offline
No, different, cases, different crank, different cylinders. The cams and pistons quite possibly are the only things that may be common between the two.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 10-03-2011, 12:17 PM
jrs14855 jrs14855 is offline
Default 0 320/0 360
Many of the later model crankcases fit either 0 320 or 0 360(parallel valve)Cylinders and crankshaft are different. Oil sump and carb are different.
