Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 10-02-2011, 08:54 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Anybody doing Checklists on a 696?
Garmin has a free Checklist editor on their website for the G1000 and GPSMAP 696. I downloaded it and have started building a checklist. However, when I looked in my 696 manual, I didn't see any reference to checklists.
Is this a new option that was provided in a software update? If so, is anyone using it?
Is there any documentation on how to use the checklist function? I'm guessing it needs to be written on the SD card because that's how it's done for the G1000. I don't recall seeing Checklists on the Menu, but to be honest, I never looked for either.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 10-02-2011, 09:01 PM
newtech's Avatar
newtech newtech is offline
Yes, you save the checklist file to a SD card and the 696 sees the file when it boots up. It gives you a soft key for checklists when it sees a check list file.
______________________
Steve Eberhart, W9JUQ
3EV - Evansville, IN
Where is Steve and the Sky Terrier?
RV-7A Slider, O-360 A1A, Catto 3 blade, 2 screen Garmin G3X Classic, GTN 650, Bionics APRS. FLYING since June 24, 2009
EAA Chapter 21
Old 10-03-2011, 05:25 AM
SmilingJack's Avatar
Default Garmin Checklist
I loaded my checklist with Engine Power tables and use it that way instead of in the normal checklist mode.
Its good, very easy to update, but I use my AFS4500 screen for the aircraft checklist.
John Mastro
RV-8
Old 10-03-2011, 08:48 AM
dfechter dfechter is offline
Default More ACE checklist info
I put some ACE checklist info along with my checklist on http://11hc.44rf.com. It "might" be easier to edit what I have -- but maybe not. You can also open the ACE checklist with MS Word and use it as a paper checklist without retyping it all.
