09-29-2011, 09:38 PM
Inserting Gear Leg
I was unable to insert my right gear leg enough to line up the mounting holes:
https://picasaweb.google.com/lh/phot...eat=directlink
Any suggestion?
Thanks in advance,
Robin
Reason: fix picture link
09-29-2011, 10:00 PM
Oddly enough, though the image link seem Ok, it keeps taking me to my own pictures. Anyway, you may have to hone the gear leg down a bit. Both of the ones on my -6A required this. First, use a Dremel or similar to put a slight chamfer around the socket openings, just to make sure no powdercoat is interfering. Then take some emery cloth and polish the gear leg. Clean thoroughly, oil lightly, and try again. Rinse and repeat until it fits. It took a few repetitions on my gear legs to get it to fit right. Better to sneak up on it than take too much at once and have it fit loosely.
EAA Technical Counselor #5357
09-29-2011, 10:24 PM
Just fixed the link...
... hopefully it is working now.
Thanks, Patrick, I will try that.
09-29-2011, 10:56 PM
Robin, purchase a big blue Mark-A-Lot and paint the leg till it is all blue. Then slide it in and remove it and look for skuffs in the blue. Sand down just that spot, the re-blue and try again. Looks like you are really close.
Clean off all of the blue when you are done.
09-30-2011, 04:43 AM
I installed the main gear legs last week. All I did was squirt a bit of WD-40 into the gear bracket, then try, try, and try again to get the "angle if the dangle" just right to allow the top portion to slide in. Once you manage that, she's apples.
For some reason, the left gear leg fought me every inch of the way. The right one slid in easy as you please once you got the angle right.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Reason: Bloody IPad auto-correct.....
09-30-2011, 06:11 AM
It is recommended that you coat the parts with grease before installing, helps with installation and preservation.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
