Old 05-13-2006, 04:14 PM
cleve_thompson's Avatar
cleve_thompson cleve_thompson is offline
Default Inserting Rod End Bearings in Elevator
I am trying to finish the enpennage before my RV 9A quickbuild comes in next week and I can't get the rod end bearings into their nutplates on the elevator and I guess the rudder as well. I scarred up one terribly trying to use a crow's foot wrench that was just a "smidgen" too large. I have ordered another from Van's but don't want to mess-up the rest of them.
I have seen, in looking through the old posts, that Boelube will help make the installation easier. Any experience with this? Even if it does ease the amount of torque some, what tool will I use to turn it in if fingers don't work.
Cleve Thompson
Old 05-13-2006, 04:43 PM
jcoloccia jcoloccia is offline
Avery makes a slick tool for this. You can make one out of PVC, or chop up an old socket (14mm works well, I think). I tried both and then spent a couple of bucks and bought Avery's. Problem solved.
John Coloccia
www.ballofshame.com
Former builder, but still lurking 'cause you're a pretty cool bunch...
Old 05-13-2006, 04:47 PM
Ironflight's Avatar
VAF Moderator / Line Boy
boeloube is magic stuff for gettign things into nutplates for the first time - I use on everything that goes into one - large or small.
I agree that Avery's tool looks like it will do the job, but being cheap, and having lots of PVC laying around, I made the tool, and it worked fine....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-13-2006, 04:56 PM
AntiGravity's Avatar
AntiGravity AntiGravity is offline
Default Boelube
I think it was Dan's website that first mentioned Boelube paste; MAGIC!!
I made the tool from an old pipe; it was a very thick walled metal pipe, so I heated it up and squashed the end until it fitted. It was 'ok', but next time I did an Avery order I just added the 'proper' tool to the order. Just a few extra dollars and it fits much better than my squahed pipe ever will...
Jeff Preou
Hamilton, New Zealand
STATUS: not building anything at all... yet ...
http://www.preou.com
http://www.kitlog.com/users/index.php?user=jpreou
Old 05-13-2006, 04:57 PM
Peetie the Pilot Peetie the Pilot is offline
I know they can be quite tight going into the nutplates but I don't recollect them being as tight as you say they are. I have noticed a few times that there no threads in the nutplates (more so on the smaller sizes). Just verify the threads are there and you are not trying to "cut" new threads.
Peter
RV-9A Flying
Old 05-13-2006, 05:13 PM
gpiney gpiney is offline
Go to the Aviation section of Wal-Mart and pick up a Gator Grip. $8-9 bucks well spent. Fits the bearings perfectly and doesn't leave a scratch.
Don't knock it till you try it.
Greg Piney
RV-8 2547
Empennage Done!
Beginning Fuselage Final Assembly!
(Tub finished, on to Landing Gear).
Old 05-13-2006, 05:31 PM
pmercier's Avatar
pmercier pmercier is offline
Default Canadian tools
what do Canadians do with old hockey sticks?
We make rod end bearing tools.
Philip Mercier RV-4 FK RV-7A flying
Abbotsford BC
http://members.toast.net/pmercier/project2
Old 05-13-2006, 07:18 PM
smithhb's Avatar
smithhb smithhb is offline
Default Tap the Nutplate
I had trouble with getting a REB to start in a nutplate on my L elevator last week and was afraid I would damage the threads on a $26.00 rod end bearing. I ordered a 3/8-24 (right hand) tap from ACS for $8.00. I received the tap on Thursday and tapped the nutplate. The REB went in perfectly...the tapping took all of 5 minutes.
Remember, the nutplate costs $.12 The rod end bearing costs $26.00. Buy the tap! Beolube will NOT correct bad threads.
Bret Smith
RV-9A Flying (N16BL)
Blue Ridge, GA
EAA Technical Counselor #5429
APRS Tracking
http://www.FlightInnovations.com
Old 05-13-2006, 07:26 PM
szicree szicree is offline
Are you sure they're the right size nutplate??
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 05-13-2006, 07:33 PM
Thank you guys for the help. Today was a bad day. Nothing seemed to work. I ordered the Rod End Bearing tool and boelube from Avery tonight. I hope that the problem is sloved....when the new bearing comes from Van's.
