The rear plug was still in place, or at least "appeared" to be in place when I mounted the prop. What I can't figure out is why the other prop governor for the higher horsepower motor cycled my prop as it was supposed to. And to further complicate things, MY new governor (the one that will not cycle my prop) DOES cycle the prop on the higher HP motor. Go figure.....
I'm completely puzzled. That's why I sent this post out to see if the higher HP governor also produced more oil pressure than the new governor for my 260 HP motor. That would make more sense *IF* there is a leak in the plug in the back of my crankshaft.
