Old 09-26-2011, 09:56 AM
pvalovich pvalovich is offline
Default EI Combinations
I've reviewed the threads discussing EI vs Mag - don't need to go there. I'm convinced EI is the way to go. My -8A Aerosport IO-360 currently sports an LSI and 1 mag. Single battery -but also have a B&C SD-8 to provide backup power. I want to go to 2 EIs and am debating the architecture.
Because of the self-contained capabilities of the P-Mag, I'm leaning toward 1 LSI and 1 PMag.
Anyone have any comments on the pros/cons of that configuration?
Old 09-27-2011, 05:56 PM
Danny King's Avatar
Danny King Danny King is offline
Default P-Mags
Sell LSI, Mag, and B&C SD-8 (unless you need it for something else) and buy two P-Mags. You won't look back.
Danny King
Beautiful Doll 80434 TT 1675 hours
I0360 A1B6 200 HP
Christen Inverted Oil
First Flight 12 July 2000
VAF Dues current for 2020
Old 09-27-2011, 06:42 PM
N941WR's Avatar
N941WR N941WR is offline
The two different EI's will fire the plugs at different times due to the timing maps programmed into them.
It is best to get two identical ignitions, be them P-mags or LSi or whatever.
My preference is the P-mags.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 09-27-2011, 06:44 PM
Walt's Avatar
Walt Walt is offline
Just add the second LSI, that's what I did and "have never looked back"
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 09-27-2011, 11:44 PM
drakerv drakerv is offline
Default Lsi
I agree with Walt.
Old 09-28-2011, 07:34 AM
Danny King's Avatar
Default P-Mag
I seldom do a follow up in an opinion based discussion, but here are a few more thoughts.
The P-mags are completely self contained in a smaller and lighter than standard magneto format. There are no separate coils, sensors, or boxes to mount. Like a magneto, they are self energized. If the battery switch is left on, a single 9 volt transistor battery will power them up for a hand start. Timing them is so simple a caveman could do it!
I believe P-mags represent the state of the art in aircraft ignition.
Danny King
I0360 A1B6 200 HP
