Old 09-25-2011, 12:39 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default elevator balance vs. manual trim cable
I've read through as many old posts as I can find, but not of clarity on this particular issue. While it does not appear that elevator balancing is really all that necessary on RVs, I'm going to balance mine as best I can. Howeer, I find that the manual trim cable, being as stiff as it is, exerts enough pressure to significantly change the angle at which the elevator naturally likes to sit.
Question: Do I balance the left elevator with the trim cable attached or out of the way entirely? I've read one or two posts that suggested doing it without the trim cable attached, but does it help to balance the left elevator without the trim cable if the trim cable's only going to have the tendency to pull the elevator out of balance when attached?
Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 09-25-2011, 01:11 PM
sbarger24's Avatar
sbarger24 sbarger24 is offline
I just went through this, as my plane is painted now and wanted to make sure my elevators were balanced. I loosened up the trim cable and inspection plate, so that it was not pulling on the elevator, but left them in place.
I ended up taking 4 oz out of the right elevator and adding 8 oz to the left elevator.
Steve Barger
RV-7A slider
Aerosport Power O-360
My RV was born in Reno, but now lives in Grand Island Nebraska
Phase I completed, enjoying Phase II
Old 09-25-2011, 01:29 PM
Andrew M's Avatar
Andrew M Andrew M is offline
Default Balance
Production aircraft generally require that all trim components be installed, but not hooked up to the airframe part of the system. (as in on the bench) I believe the forces in play during flutter have more to do with mass than springing forces, as some production airplanes have spring assist which are not accounted for during (mass) balance.
I sure would like to hear what the educated have to contribute about this.
Andrew Miller
A&P, IA
-9 empennage
Wings arrived 12 JAN 13
https://plus.google.com/photos/11360...J-TuJPsmOONzQE
Old 09-25-2011, 01:52 PM
Bavafa Bavafa is online now
Keep in mind that the balance need to be in final assembly and not just individually each elevator. But I suspect that if each of them are balanced, then as an assembly it will also remain balance. In my conversation with VANS during my final assembly, they were very clear and admament about that.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 09-25-2011, 02:02 PM
sbarger24's Avatar
That is good to know and yes mine are balanced as an assembly now too. Sounds like I cost myself a little extra work is all.
Steve Barger
RV-7A slider
