Old 09-25-2011, 12:35 AM
Mike D's Avatar
Mike D Mike D is offline
Default alternate static port location?
I have searched but cant seem to find any related posts, so....
Have you installed an alternate static port? If so, where did you put the switch. Stein sells a toggle switch that provides a alternate static air and I am wondering where to put it. Is there a standard location?
I would like it to be out of the way, but visible in case it is needed.
Michael Delpier
RV6A -O-320, fixed pitch, GRT Sport, 496
RV-10 - working on finish kit
Houston
Old 09-25-2011, 01:04 AM
MauiLvrs's Avatar
MauiLvrs MauiLvrs is offline
We went the simple route.
Kinds like the old Mooney's' method.
Break something
In the Mooney's you broke the VSI.
Have knife, have static line, cut static line with knife
Experimentals are prohibited from flight into known icing...
We have two static ports, one on each side.
If the static/pitot system fails, the air data is supplemented by the GPS.
Chance of failure small.
Chose to keep it simple and not add the complexity, cost, and weight of an alternate other than the line and the knife that we always carry on board.
Dave & Trina
RV-9A Flying - 330 Hrs. Painted Finishing the interior.
Old 09-25-2011, 05:02 AM
pierre smith's Avatar
Default Easy
Simply vent it to the cabin. It may not be precise altitude or airspeed but close.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 09-25-2011, 08:23 AM
N941WR's Avatar
N941WR N941WR is offline
Just install a "T" fitting with a removable plug in the cockpit. Heck, you could run a line off that "T" to your panel.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 09-25-2011, 09:48 AM
SteinAir SteinAir is offline
Most of the builders I know except for the pressurized guys vent the alternate static to the cockpit. Heck, there are a few that vented their primary static to the cockpit! Anyway, If one is frozen on the outside (two in the case of an RV and most planes), it'd be likely that any other outside ones would also be frozen.
Plug in the t thing is ok as long as you have things mounted where you can get to them. Also do a test on it, sometimes those things don't work as easy as you think. Basically you just install the switch, plug it into your static system like any other unit and leave the other side open.
My 2 cents as usual!
Stein
Old 09-25-2011, 10:06 AM
aerhed aerhed is offline
Sitting just below the flap & dimmer switches.
Actual repeat offender.
Old 09-25-2011, 10:07 AM
Mike D's Avatar
Guess I am over thinking this.
I hadn't even thought about not venting to the cabin air. But during my search I now know there are heated petot tubes with a static port. I won't be doing this. I am flying an RV not a Lear jet.
But now that I have this nice alt static toggle switch, where do I mount it? On the panel or under the dash? I guess that is up to me.
I have had only one instance of a plugged static port, and it was because of bugs. I have absolutely no intention of ever flying near freezing conditions that would cause the static port to becomes blocked. And there is no way I am going to break the glass on my EFIS.
Michael Delpier
Houston
Old 09-25-2011, 11:44 AM
jjconstant's Avatar
jjconstant jjconstant is offline
One benefit of having alt static is for troubleshooting. I was having auto pilot oscillations in pitch during any turn which went away when I used the alternate static source. Proved that the problem was with the static source on the pitot tube. The external static source is now in the Van's standard location. There may be other instances where it can help in troubleshooting.
Jeremy Constant
Old 09-25-2011, 12:07 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
My 6A has one. They were real cheap at the time I bought it. Now they're close to 10X as much. It's worked well, though. In the meantime, I added the Van's static ports on the rear, for the altitude A/P. Have a line going forward to the panel, for a future alternate.
L.Adamson
Old 09-25-2011, 02:50 PM
Bavafa Bavafa is online now
Here is where I have installed mine on the panel.
DSC_6148 by bavafa1, on Flickr
You can see it on the far left side with a protective cover. As the cover is closed, the switch is automatically closed as well. This is all within easy reach and observation that can not be left open by accident.
DSC_6147 by bavafa1, on Flickr
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
