cylinder temps
any possibility of getting some of the baffle seals turned backwards during cowl reinstall? I don't think the plugs or blast tube would have that kind of effect.
On RV7A I have to reach through the oil door and verify they are all facing forward so they seal to the cowl with the air pressure on the top of the engine.
Larry Buller
RV7A slow build, Tip up, IO360 200hp, Catto 3 blade, Dynon Skyview, arinc 429, ems, SV transponder, Garmin GNS430w, Aera 560, Dynon D6.
FLYING!
