If you live in Washington State, this might be of interest to you; saw it in the "Happenings" newsletter at
www.PaineField.com. I have no affiliation with it whatsoever, just passing the information along. I have lived in Texas for the last 8 years, but took my first flight lessons at Paine Field and grew up one mile away... anyway, I was "nostalgic" this morning, which had me looking at their site to see if the airshow I used to attend is still held there each year--apparently, it is not.
VOLUNTEER AIRCRAFT NEEDED:
Experimental aircraft with Lycoming engines are
needed to test a new electronic ignition system.
They will work with you and your aircraft to test the
new system. After testing, the entire system will
be given to the aircraft owner.
Call Alan Jesmer from Precision at (360) 651-8282
