Old 09-22-2011, 03:39 PM
jmjula's Avatar
jmjula jmjula is offline
Default Co-pilot stick removal
I can't find the thread I am looking for. Does anyone know where to buy a button clip/push button spring for securing the passenger stick, yet allowing it to be easily removed?
James Jula - CFI/II/MEI - N713JL RV-7A First Flight 10/12/15 - "What is chiefly needed is skill rather than machinery." Wilbur Wright, 1902
Old 09-22-2011, 03:44 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
There may be a Vans service bulletin on this suggesting using specific hardware.
Old 09-22-2011, 03:52 PM
Brantel's Avatar
Brantel Brantel is offline
McMaster Carr
Telescoping tubing quick release pins
http://www.mcmaster.com/#pins/=e6eiwb
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 09-22-2011, 03:59 PM
bkilby's Avatar
bkilby bkilby is offline
http://www.jergensinc.com/site/sfg_k.../group_no=1352
Brian Kilby
flying RV-6A, previously flying RV-9A
based at KCTJ, Carrollton, GA
Old 09-22-2011, 05:23 PM
hydroguy2's Avatar
I used the quick release from my broken kayak paddle...cost was only $100....for the paddle.
Old 09-22-2011, 06:06 PM
frazitl's Avatar
frazitl frazitl is offline
Default I have half of a
key chain holding mine in. It works just like the quick release pins on the McMaster-Carr site. My half key chain only goes thru one side of the socket weldment and the stick, but it has never failed to stay in place. I tied it to the stick with a lanyard so it can't be dropped between the sub floor and the lower skin. Cost - couple bucks.
Terry F.
RV 7A N457RV
250 hours and lovin it!
Southern Nevada EAA Chapter 1300 - www.eaa1300.org
Paid VAF 03/17
Old 09-22-2011, 06:30 PM
bruceh's Avatar
bruceh bruceh is offline
I have the push pins from McMaster. They make you buy a pack of 5, so I have a couple to give away. PM me if you want one.
UPDATE: All gone!
Bruce Hill
2020 VAF donator
Old 09-22-2011, 10:35 PM
Bill Phillips Bill Phillips is offline
Default James, I ordered a spring button from
Mcmaster-Carr and installed it in the rear stick in my new RV-8a. Easy to install, easy to use, works great. I'd recommend the quick release button to remove and install the stick. Good luck! Bill Phillips, N288WP, RV-8a 20 hours into Phase 1
Old 09-22-2011, 11:51 PM
BigglesRV7A BigglesRV7A is offline
Default Vans Service Bulletin
There is a service bulletin out on control sticks as Ron mentions above:
http://www.vansaircraft.com/pdf/sb07-2-6.pdf
Worth a read through before you commit to anything less than their recommendation.
Cheers, Greg
Old 09-23-2011, 10:42 PM
cubdriver cubdriver is offline
Bruce. I will take one of the pins. Also in Ramona building an RV9a. I will be at the open house tomorrow - hanger Is second from the end next to transient parking with a 1940 j3 cub . Am currently working on canopy for the nine. Jim Potter
Jim Potter - Ramona, CA
RV9A Owner- landed it at Osh on yellow dot
Previous Owner of 1940 J3 Cub
Currently Building RV14a
jim.potter@cox.net
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
"There's a big difference between a pilot and an aviator. One is a technician, the other is an artist in love with flight." - Elrey B. Jeppesen
