09-20-2011, 07:05 PM
Avionics powered up, no smoke! But...
I can hear my relays clicking in the headset. I have one set in the floor operating the flaps and trim, and another one on the subpanel activating the starter solenoid. All the avionics (430W, GMA340, GTX327, odyssey) are all grounded on a common forest of tabs attached at the firewall.
In addition to this, when I key the mic, the MGL Odyssey EFIS goes slightly crazy, showing me a 1500fpm descent and a 30 degree yaw until I let go.
What am I missing? Other than a low skill level in avionics installation...
RV-7 N313TD
SOLD 7/2/2020
09-20-2011, 08:47 PM
I'm going to say to look at your com coax and ant very carefully for your second problem.
Jay
09-20-2011, 08:50 PM
check your audio shields are connected at the audio panel only
7 empennage done
wings done
fuse done
0-360A4M Fixed pitch sensenich
Finish kit
C-GVRT Reserved
09-20-2011, 09:05 PM
Do you have spike supression diodes on the relays?
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
09-20-2011, 09:43 PM
I do not have spike suppression diodes on my relays. I've not heard of them before. Where should those be wired in? On the power lead on the hi-current side, the driven loads?
My antenna cable is RG400, and I'm pretty sure I did those right, but I don't know. What does a messed up crimp-on BNC connection look like? Would a less than optimal ground plane connection at the antenna mount be a possible culprit?
All my audio shields are definitely all grounded to the frame of the audio panel, per installation manual.
My antenna is mounted just forward of the main spar, as far outboard as I could put it, and which puts it about 2.5 feet directly below the EFIS.
RV-7 N313TD
SOLD 7/2/2020
09-21-2011, 06:48 AM
Did you ohm out your coax cables after the crimps to make sure the center conductor was still isolated from the shielding, and also that your shielding had continuity from one end to the other?
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
All relays/solenoids/contactors should have a diode installed, the same as on your master and start contactor. LINK
09-21-2011, 10:55 AM
well, I found one possible factor for the antenna issue. On one end of the cable, the pin isn't all the way flush with the plastic end of the BNC connector, which might contribute to a weaker signal and more RF radiating from the cable. The coax ohms out fine when tested, though.
I will have to revisit some of the wiring of sensor packages and the backup battery on the EFIS, I think, and definitely install the spike diodes on all relays.
Thanks for your advice.
RV-7 N313TD
SOLD 7/2/2020
