Old 09-18-2011, 03:32 PM
jeffmoreau's Avatar
jeffmoreau jeffmoreau is offline
Default Show me your Rudder Gust Lock
Please post a photo of your Rudder Gust Lock. Especially for a RV-8A.
Thank you in advance!!
Jeff Moreau
RV 8A
N888JM/Flying
EAA Technical Counselor
Virginia Beach, VA
Old 09-18-2011, 04:28 PM
AltonD's Avatar
AltonD AltonD is offline
Air Gizmo
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 09-18-2011, 05:10 PM
jeffmoreau's Avatar
Default Air Gizmo
I am using these for the Elevator and Aileron however it is not a good solution for locking the Rudder. The 8A sits up high on the gear and I can't get one of these on the rudder without a step ladder.
Jeff Moreau
RV 8A
N888JM/Flying
Virginia Beach, VA
Old 09-18-2011, 06:17 PM
TroyBranch's Avatar
TroyBranch TroyBranch is offline
Default Some options in this link.
http://www.vansairforce.com/communit...er+lock&page=2
Troy Branch
RV10 Built and Flying Since Feb 2009
950hrs Plus
CC EX-2 Flying
SuperSTOL Built and Sold
RV9 Built and Sold
Avid Aerobat Built and Sold
Dues paid Nov 2019
Old 09-19-2011, 09:23 AM
jeffmoreau's Avatar
Default Bump
Bumping this thread.
Jeff Moreau
RV 8A
N888JM/Flying
Virginia Beach, VA
Old 09-19-2011, 09:51 AM
Tim 8-A's Avatar
Tim 8-A Tim 8-A is offline
I will get a picture of mine and post it.
Do you have external rudder stops? I drilled mine and use a U shaped pin between the two.
Tim Blake
Colleyville, Tx
RV8a Purchased flying (many changes) Sold
RV-10 Purchased flying.. Panel upgrade complete.
G3X/Dynon/TT
All new interior complete.
Flyin like a dream.
Old 09-19-2011, 04:39 PM
pauldan181 pauldan181 is offline
Default One option
I bent up a piece of mild steel and added a couple of screws and plain nuts. I just drop the brace in and run the nuts down finget tight.
Paul Danclovic
Jamestown NC
RV-8A N181SB
Old 09-19-2011, 05:06 PM
jeffmoreau's Avatar
Default Yes I have external stops
Yes,
I have the external stops as per the plans. I am eager to see a picture of your set-up.
Thanks!
Jeff Moreau
RV 8A
N888JM/Flying
Virginia Beach, VA
Old 09-20-2011, 05:47 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
I also bent a U shaped pin and drilled the stops for the pin. I heated up the corners and bent them very square. I also left one leg longer and drilled the shorter leg for a hairpin and warning flag. Very simple and fast to install and remove. Sorry I can't find a pic. It is similar to Paul's, but you don't need the nuts and washers, just the hairpin clip on one leg.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 09-20-2011, 11:12 AM
rzbill's Avatar
rzbill rzbill is offline
Default Diamond Eclipse style control lock
I used to fly a low time DA-20 rental that had all the parts and was in working order (y'know the rental blues ).
Included was a control lock that I liked. I have recently done the initial fabrication of one for my -7A. The strap locks are mounted in out of the way positions on the lower edge of the panel.
The rod is an old aluminum tube tent pole with an ultralight plastic tube saddle (out of one of my many jars of airplane stuff) to nest the stick and a roll pin at the other end to engage and push the rudder pedals.
Below is a pic of the web locks. I potted the belt loop area with marinetex epoxy (many will work of course) so I could make a bolt hole.
Bill Pendergrass
ME/AE '82
Last edited by rzbill : 09-20-2011 at 06:04 PM. Reason: reduce image size - added second image
