Old 09-16-2011, 12:37 PM
ron sterba ron sterba is offline
Default Screws and tool for lightening hole edges,Where?
I decided to go with all torx head screws or Hex anywhere under the panel. Seems with the nutplates those #2 phillips strip out so easy if you cannot get a perfect fit. Spruce does not seem to offer on their hardware page. Need a supplies for aviation grade screws.
I'm not sure what they call the tool that makes the half-round edge of a lighting hole. I know there's something out there. I have not paid much attention until I got that hole drilled and said IT WOULD SURELY BE NICE TO RAISE THE EDGE).
Appreciate any help!
Ron in Oregon
Old 09-16-2011, 12:40 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
I think this is the lightening tool you are looking for - http://www.averytools.com/prodinfo.asp?number=1041
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 09-16-2011, 01:32 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Hi Ron,
Here they are right here: http://www.aircraftspruce.com/catalo...es/NAS1351.php Just bought some from Spruce to put my tank cover plates back on after doing the SB. Cost me about $15.00 in screws but am hoping it's worth it if I ever need to crack into the tanks again when the wings are attached to the fuse.
That said, if what you're using them for is non-structural behind the panel, you may find something completely adequate and much cheaper at your local ACE aircraft supply.
Just FYI, #8 socket screws require a 3.5mm hex drive, so pick one of those up if your 15,000-pc home mechanics tool kit, like mine, doesn't have that size!
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 09-16-2011, 01:46 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Why not use Genuine Aircraft Hardware Co. ?
http://www.gen-aircraft-hardware.com/
The owner, Tom, is an active member of VAF, and a RV builder.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-16-2011, 11:54 PM
Thanks guys , I hit the jackpot on both items . QB9A putting the fuel and oil lines on now! Just finished canopy with Sikaflex. Real happy with the canopy.
Ron in Oregon
Old 09-18-2011, 12:25 PM
Roy Thoma's Avatar
Roy Thoma Roy Thoma is offline
Ron,
Check microfasteners.com Look for "6 lobe drive" fasteners (Torx equivalent). http://www.microfasteners.com/catalo...y=0&sterm=lobe should go to a search result for button head and 100 degree 6 lobe drive screws.
Regards,
Roy
Old 09-18-2011, 04:42 PM
vfrazier's Avatar
vfrazier vfrazier is offline
Another option for the lightening hole edge treatment:
Flanger 360
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 09-19-2011, 02:28 AM
Vince thats the one I was looking for. I finally found it!
Thanks Ron
Old 09-19-2011, 02:34 AM
Thanks Roy. Great website on the screws. Thanks for the direction on the hinges. I start those on Monday. How's that new 7A of yours doing? I'm assuming 150 hrs? Whats it been 3 months? Great job Roy!
Talk to you soon. Ron
