BB,
There are very few of us in this boat, I suppose, as many wet pumps were replaced with dry pumps years ago. I have one on my Pacer, and while it is still operating nominally, I have also been looking for a repair kit. As you have also discovered, they don't seem to be easily located.
Have you tried contacting a shop that O/H these units to see if they can help you? If I recall correctly, you stated that you feel that your pump has a worn seal. Might it be possible to get the seal out and source a new seal through a good supplier?
I will keep trying to find more info, and would appreciate it if you could keep us (me) posted on what you end up doing.
Mark Ohlau
RV-6 N506MM VAF #1410
2017 Donation Made
