Old 09-16-2011, 07:27 AM
turbo's Avatar
turbo turbo is offline
Default condition inspection sign off?
does the inspection need to be signed off in both the airframe and engine log books? thanks
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 09-16-2011, 07:39 AM
Walt's Avatar
Walt Walt is online now
Airframe only.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 09-16-2011, 07:50 AM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by Walt View Post
Airframe only.
What Walt said...
You don't even need to write the engine compressions in the engine log, if you don't want to.
I keep my completed condition inspection check list with my logs as a record of what I performend and found. Anyone who may purchase my plane in the future is going to get a file folder of those things.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 09-16-2011, 09:33 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
The FAA does not use the term "log books" in the FARs.
They say "maintenance records" - your file folder qualifies...
How you keep your records is basically up to you - but with restrictions on computer records...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-16-2011, 09:54 AM
gasman gasman is offline
You guys must be talking about the AIRCRAFT logbook.
None of my planes have ever had an airframe logbook.
Where can I purchase an airframe logbook?
Old 09-16-2011, 09:55 AM
mrreddick mrreddick is offline
Super Moderator
Location: Hangar/home at Hicks Airfield (T67), Fort Worth, TX
Default Maintenance Records
May not be an official requirement but the A&P I use signs the condition inspection in my airframe, engine, and prop logbooks.
Mike Reddick
VAF#153
Pilots N Paws Pilot
RV6A N167CW 1,900 HRS
Ft Worth, TX (T67)
Old 09-16-2011, 10:08 AM
"Fixed-pitch propeller aircraft do not have a Propeller Logbook because the propeller is considered part of the airframe."
Just a quote from this guys web site......... http://albuquerquedpe.com/Inspections.aspx
Old 09-16-2011, 10:41 AM
az_gila's Avatar
Smile
Sensenich thinks otherwise and ships you a propeller log book with their certified props...
If you get an experimental prop, you get to print out your own log book....
http://www.sensenich.com/files/docum...1287584172.pdf
Gil Alexander
Old 09-16-2011, 04:01 PM
kbehrent's Avatar
kbehrent kbehrent is offline
Question C/S maintenance recording
I have the Hartzell C/S prop from Van's that came with a prop log book. Other than major items such as a prop/hub overall, what would you normally record in the prop log book during a condition inspection?
Kevin Behrent
TeenFlight Puyallup, President
www.teenflight.org
http://facebook.com/teenflightpuyallup
EAA Chapter #326
Puget Sound, WA
RV-9A
Aerosport (Superior XP) IO-320 C/S, Precision Eagle EMS
Old 09-16-2011, 04:11 PM
flion's Avatar
flion flion is offline
I record the inspections called for in the prop manual. Similarly, I record the inspections Superior called for in my engine log. Those inspections are based on flight hours and don't necessarily coincide with the condition inspection. Like Bill, I keep my condition checklist, which has a section for findings and corrective actions taken. If any item is major (like the time I replaced a starter and ring gear), then I record it in the appropriate logbook but the condition inspection sign-off from my airworthiness only goes in the aircraft log.
EAA Technical Counselor #5357
