Old 09-15-2011, 11:59 AM
sailvi767 sailvi767 is offline
Default Ouick Oil Change Question
Does anyone know with the safe air quick change valve what diameter tubing you need to slip over the fitting for draining the oil? I am guessing about 3/8 inch inside diameter but wanted to pick some tubing up on the way out to the airport.
Thanks!
George
Old 09-15-2011, 12:21 PM
caryr's Avatar
caryr caryr is offline
use 1/2 "
may have to neck down the top a bit with a couple wraps of safety wire.
The larger diameter flows better.
Cary Rhodes
Taylorsville, Georgia
N203CR
Van's RV-7
First Flight April 2004
Old 09-15-2011, 02:19 PM
guccidude1 guccidude1 is offline
George: I use 3/8" ID for the drain hose. Dan
