Old 09-15-2011, 11:16 AM
dpansier's Avatar
dpansier dpansier is offline
Default Programmable Indicator
Interesting device for aircraft applications
This programmable indicator has the ability to be loaded with up to 30 seconds of WAV or MP3 files via USB and at a low cost of $23 it could be used for a number of aircraft applications.
Safety uses that come to mind are a fire detector, a thermo switch placed in the engine exhaust cowl area could activate this device emitting a aural fire checklist.
http://www.digikey.com/us/en/ph/pui/...indicator.html
Don Pansier
Green Bay, WI (GRB)
RV-7 N450DP
W9LYX
Antennas for Experimental Aircraft
www.deltapopaviation.com
