Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 09-15-2011, 12:31 AM
ratc's Avatar
ratc ratc is offline
Default MT Fixed Pitch propellers with dual EI?
Some time ago I was advised by MT that they would NOT support the use of their Fixed Pitch Propellers when used with dual Electronic Ignition, for me dual P Mags.
The good news is Martin Albrecht at MT has just confirmed this is no longer the case.
I suspect that Jim Ayres has had something to do with this since he has been working on using Dual EI and an MT FP propeller........Thanks.
I hope Brian Vickers sees this!
Andy
RV-4
#4411
G-RATC
Old 09-16-2011, 08:40 AM
RVjim's Avatar
RVjim RVjim is offline
Default MT fixed pitch with duel EI
Hi All,
From my conversations with MT Propeller on Electronic Ignitions (EI), the improper timing setup of the EI has been the main problem. And the first item to suffer from improper timing setup has been the propeller.
I've installed the ElectroAire, LightSpeed and Pmag systems.
The Pmag is, by far, the easiest unit to set the timing.
Jim
