Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 09-14-2011, 04:56 AM
pierre smith's Avatar
Default Runway numbers on a 496
The other (696) thread has this discussion.
My 496 once showed the runway numbers on the little red airport diagram but they've disappeared. How can I get them back? The manual is of no help here.
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 09-14-2011, 08:02 AM
Default No worries.
Garmin just told me how.
From the Map page
Press 'menu', Press map setup, scroll to Avn nav, then down to 'runway numbers'. First should be "small" then scroll right, press "enter" and select the distance from your destination that you want runway numbers to show.
Best,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
Old 09-14-2011, 08:13 AM
Walt's Avatar
Walt Walt is offline
Exactly what I am looking for in the 696!
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 09-14-2011, 08:34 AM
Mel's Avatar
Mel Mel is offline
Default Thanks!
Best,
I've been trying to figure out what those numbers meant.
I didn't know if that was a "screen range" or what. Good to know that that's the distance from destination.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-14-2011, 03:08 PM
N363RV's Avatar
N363RV N363RV is offline
Default I had no idea....
I had no idea that the 496 could do that. I'm going to try it out tonight.
Thanks Pierre!
Old 09-14-2011, 03:13 PM
mburch's Avatar
mburch mburch is offline
No, it's actually the minimum map zoom range (corresponds to the range number on the map scale in the lower right corner of the screen).
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 09-14-2011, 07:27 PM
Mel's Avatar
Mel Mel is offline
Thanks Matt,
That was my original "guess" but I wasn't sure. I couldn't find where the manual even mentioned it.
Old 09-15-2011, 04:50 AM
Default Another setup
Thanks Pierre!
One of the handiest safety features of the 396/496 is that you can also select soft/grass fields to show up when you press the "nearest" button.
I set mine up to show ALL airports with 2500' or longer runways.
Press "nearest" and then menu and you can change the default settings to not show heliports or water runways, as well and put in your minimum 'feel good' runway lengths.
When I did this, it added 4 grass runways to the first page that weren't there before. Y'never know when the cooling fan may pack it in!
Best,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
