Old 09-13-2011, 07:04 AM
tonyjohnson tonyjohnson is offline
Default Filling in holes in panel
I need to fill it and redrill 4 small holes in the instrument panel. I misaligned the holes to mount my clock. I am considering
1. Taking the panel to a welder
2. Using a product like JB weld
Any thoughts or suggestions?
Tony Johnson
RV8A "Badboy" N12TJ
Treasure Island Florida
Old 09-13-2011, 07:10 AM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Rivet
I assume you want to move the clock slightly. One possibility might be to drill, countersink, then rivet the holes. Re-drill the correct ones. Grind down the shop heads on the back side if they interfere. But I would think that JB Weld would do just as good a job as hole filler.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 09-13-2011, 07:21 AM
Default holes
Don,
I enlarged the holes to properly align the clock. The original holes had it canted. So, I need to fill the holes and redrill them to eliminate the slop.
Tony Johnson
RV8A "Badboy" N12TJ
Old 09-13-2011, 09:02 AM
Greg Arehart's Avatar
I would think either of Don's solutions would work. Alternatively, some microbubbles and epoxy, since its not structural.
greg
Greg Arehart
N 7965A
Old 09-13-2011, 10:52 AM
Default It is hard to say this but ...
If the holes don't show and you now have the clock aligned properly there is really no need to do anything. The potential for defective workmanship drilling into an area containing two different materials is not zero. Oversize or slotted holes are not uncommon for fine tuning instrument alignment.
Bob Axsom
Old 09-13-2011, 10:56 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Another solution is to make a little trim bezel out of .040 with the holes drilled properly to the clock. Then slot the holes in the panel - the bezel hides the slots and makes the clock look like "big iron" with little cut-off corners. Trim plates hide many sins....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-13-2011, 10:58 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
What Bob said.
If they do show, and you want them filled, dont weld them, too much chance of distorting the panel.
Your instrument panel is probably .050" or so thick, maybe more. You can do a double countersink, and rivet it with a slightly long rivet----then grind off the shop head, and the double countersink will still hold the rivet in.
Been there, done that.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-13-2011, 10:59 AM
Mike S's Avatar
Senior Curmudgeon
Paul
Sounds like the voice of experience
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 09-13-2011, 11:00 AM
Brantel's Avatar
Brantel Brantel is offline
JB weld does great for this type thing and after you paint over it, you will never know it is there.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 09-13-2011, 04:58 PM
chaskuss chaskuss is offline
Paul
Tony,
How far off are the original holes from the correct ones? If you simply had to slot the holes, perhaps you could simply install flat washers to hide the mistake. If it requires larger flat washers, you could trim them to fit around the clock.
If washers won't hide it, I like Paul's idea.
Charlie
