Old 09-12-2011, 07:37 PM
highflight42x highflight42x is offline
Default question on engine shock mounts
How often should one replace the elastometric shock mounts on an engine installation? Mine are the 'Lord' type, 22 years old, with 650 hours on my RV3. I'm going to pull the engine off to do some magneto work soon, and wondered if I should replace the shock mounts while I'm at it?
Old 09-12-2011, 08:33 PM
Walt's Avatar
Walt Walt is offline
I would, normally they are replaced at TBO, I think 22 years qualifies as TBO.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 09-13-2011, 08:43 AM
LarryT LarryT is offline
Default Replace engine isolators?
Yes. Be sure to bite the bullet ($$$-wise) and get the actual Lord mounts. The <$ competitors eliminated the silicone gel guts in order to lower the price. This is definitely a case where one gets what one pays for. I shopped around and remarkably enough got the best price from Jeppeson (!???!).
LarryT
Larry Tompkins
N544WB RV-6A purchased flying
W52 Battle Ground, WA
Old 09-13-2011, 08:45 AM
rocketbob's Avatar
If they're not heat checked and not excessively stretched, I'd leave them alone. $500 for mounts saved can buy a lot of gas. Well maybe not so much anymore.
That said I rub mounts with DC4 to keep them from drying out.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 09-13-2011, 09:08 AM
flyingriki's Avatar
flyingriki flyingriki is offline
The Sac Sky Ranch manual has a diagram with allowable limitis of stretch and sag. Might be a good guide for your decision. Mine are 15 years old and sagging pretty bad. If not too bad you might consider flipping top to bottom or adding spacers to the lowers to bring it back up where it shoud be. Both suggestions I got from knowledgeable folks in the business.
Old 09-13-2011, 09:48 AM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
The Lord manual is here -
http://www.herberaircraft.com/pdf/Di...ide_PB6304.pdf
Inspect them per the numbers above...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-14-2011, 12:20 AM
Great answers, guys. I shall consider all the advice given! Thanks -
- Steven
Old 09-14-2011, 12:39 AM
RVadmirer RVadmirer is offline
http://www.sacskyranch.com/lord.htm
