Old 09-12-2011, 05:34 PM
Darren S Darren S is offline
Default First Aerobatic Contest :)
I just came home from competing in my first Aerobatic Contest. What fun !! Challenging, exciting, educational and nerve wracking all wrapped up in one.
The contest was held at the Rocky Mountain House (CYRM) airport up here in Alberta. I think it?s division 7 and a few guy from Division 8 showed up to compete and help.
I fly an RV-7 with a 180 hp Superior engine, Hartzell prop, no inverted oil. I had the aerobatic restriction removed earlier in the year and then had some dual instruction time with an instructor. Some of our final lessons included some ground critiquing as I was being groomed for the contest.
Being my first contest I wasn?t sure what I was in for. To ease some of the competition day nerves I flew to the site to practice in the box and also to try on the mandatory parachute. I wanted as few ?new? things to deal with on the day.
Local flair - Sportsman Category
I believe the box is 1 kilometer square but it sure looks small from 1500 agl and at the speeds the RV?s travel it doesn?t take long to get from one end to the other. The box is marked with white corners and a big ?X? in the center.
Practicing at the site was a great help to me as I was able to iron out some positional things and get an idea where to start pulling manoeuvres.
The day begins with registration and a pilot briefing. Safety is stressed through out and as the Chief Judge said, ?I don?t care if you do you do your figures 5 miles high, just don?t go low. I?m zeroing you if you go below the low line?. Ok note to self??.Don?t go low?.. more on that later
RV6A in Sportsman
There are two frequencies that are used. The airport frequency is for taking off and landing and anytime you are out of the box. Once airborne you are to switch to the box frequency and then head to a predetermined holding area. There are guys on the ground monitoring both frequencies and if there happens to be a stray plane entering the box the Chief will shout over the radio, ?Knock it off, Knock it off, Knock it off?. At which point the pilot is to fly straight and level and await further instructions. The airport is NOTAMed for the contest but we all don?t check NOTAM?s
The low line or the floor of the box for Primary is 1500 agl and the contest begins with a competitor fly this line to show the judges where the floor of the box is. Gives them a mental picture of where the plane should be.
Never too early to train an aerobatic pilot
My sequence in Primary consisted of: 45 degree up line, one turn spin, half Cuban 8, loop, 180 degree turn and a roll. Sounds simple enough don?t it ?. Until the stress hits you and you brain fart
The day was hot and beautiful and no wind. I practiced from a right to left direction and was glad when the Chief picked this as the direction of flight. I did practice from left to right but in the -7, since I?m not sitting in the center of the fuse, I found it hard to see the box markers from the left seat when flying that direction. I know there are box markers at the rear but I still found them hard to see.
The higher classes were flown first and then Primary. So after a 4 hour wait I was finally up to bat. I couldn?t eat because of nerves so all I did was drink and pee, drink and pee, drink and pee.
This -6 has 4 seat (two rear facing) and an IO-540 !! Cool.
Ok so here we go?.. Take off, switch to box frequency and head for the hold area. I?m hot and sweating and death gripping the stick. Finally I get the call from the Chief that the box is mine. Level off at 1800 agl, 23.5 MP and 2490 on the prop with 10.5 gph burn. Feels good, last minute trims, 3 wing wags and wait till my left wing hits the edge box marker. From practice I know this is where I should pull my 45 degree up line.
A quick pull up to a definitive 45 degree stop and watch for my IAS to hit 80 knots. In round two I brain farted and started to pull power on the way up. Never did that before. Nerves got to me. I lost speed rapidly, botched the spin as a result and was messed up for the rest of the round.
Next is a quick push of the nose to define the top of the up line. Maintain a nose high attitude.
By the way, it?s a good idea to vacuum out your plane before hand because all the grass and dirt that?s sitting on your mats will come flying in your face with any negative G pushes I now know.
I maintain that nose high attitude to prevent sinking which would happen if I went to a cruise attitude (ground critiquing). Next I pull power, maintain altitude and wait for the stall. As soon as the nose breaks, full right rudder and stick in the gut. Hold it ?? ? rotation and then full opposite rudder and nose down. Point the nose straight to the ground so the judges see a nice vertical line. I?ll be the first to admit that it?s a bit scary pointing your airplane straight at the ground, but it?s something you get use to the more you practice. At this point I better see that big ?X? marking the center of the box.
Whew?. There?s the X? so far so good. A two count, full power, pull out level, define the horizontal line and give a 3 count. The RV?s are fast and in no time I?m at the end of the box and moving fast. There is no penalty for going out of the box in Primary but it hurts the presentation if you do your manoeuvres way out in the bush.
Old 09-12-2011, 05:39 PM
Default Part Deux
My best score sheet
Worst score sheet
Next was 3.5 G pull for the half Cuban and then establish the inverted 45 downline. As the marker comes into view over the top of the half Cuban I push to establish the line?. Darn there?s that dirt and junk in the face again?.. give the inverted segment a quick 3 count, roll and then a 2 count to level out.
By now I hope to see the center box marker. Easier to see from the left seat with my favored direction of flight. Next is the loop and there is no time to dilly dally. In my second round I was too jacked up and pulled about 4.5 G into the loop. Way too much. The plane will lose inertia and speed and the ensuing loop will be an egg shape and not a donut shape. In that round I also got low and came down to about 1300 agl. I saw it on the Altimeter but was hoping the judges wouldn?t notice?.. they did. I got a 5 out of 10 on that one. Too low. Lucky I didn?t get a zero. Note to self again. Relax and pull smooth, don?t grip the stick like you?re choking a chicken! Just fly the figure and don?t muscle it around.
The 180 degree turn isn?t too tough, just don?t drop altitude during it, then finally is the roll. In the first round I tried to do a nice smooth slow roll and got nailed by the judges for barrel rolling. By the third round I said forget this. Use the speed and quickness of the RV to my advantage. It?s not like I?m flying a Decathlon (no offense to the Decath. readers) . Round three roll was a touch of nose up, full aileron and do is so quick the judges can?t find too many mistakes. Whoo Hoo it worked, I got a 9.
3 wing wags and I?m out of the box and heading for a landing. I was sweating and frankly glad it was over.
Best round was #3 when I told myself to relax and fly like I practiced. It reminded me of golf. I?ll take two nice practice swings that look and feel good but when it?s time for the real deal I?ll try and kill the ball. Wham?. Nice 40 yard shot dude
I took second place overall! I was very happy. The guy in first place flies a Pitts S1S but with a 1.5 hour range and no leather seats I?ll stick with my -7
My -7 and the Pitts that beat me. See other VAF threads to see why I have an ugly green spinner.
Finally, aviation is filled with all sorts of interesting and unique characters. I met my fair share this weekend but one guy in particular sticks out. Bob Harris aka. ?Birdstrike Bob? is someone I?ll never forget. The more I laughed the more stories he told. I wanted to find out how his moniker ?Birdstrike? came into being. Well as the legend goes he was practicing for an airshow and was inverted 50 above the runway when the fowl entered his canopy. Being in the back seat of his Extra 300 there was some hardware between the front and back seats. This allowed the stray bird to ricochet off something before bonking him in the head and then exiting out the aft of the fuse. He had the presence of mind to push to a positive rate of climb, roll level and assess. He was fully prepared to bail out but realized that he still had control. His eye was cut and could only see out of one of them but managed to get the plane back on the ground. Great job Bob!!, it was nice meeting you.
"Birdstrike" himself
So those RV drivers out there thinking of giving Aerobatics a try I would encourage you 100%. Get the training and give it a go. The planes are wonderful cross country airplanes and capable aerobatic machines in the lower classes.
The spoils
So what?s next ? Inverted oil and smoke system, join the airshow circuit and quit Dentistry?.. er ?.. maybe not, let?s not get carried away now shall we
Old 09-12-2011, 05:47 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Congrats!!!!!!!!!!!!
Darren, WOW
To pull a second place in your first contest sounds like you did very well indeed !!!
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-12-2011, 06:37 PM
panhandler1956's Avatar
Default Awesome!
Very cool! Thanks for the excellent blow-by-blow account! I'm sure that will inspire others to take a whack at it too! Count me in next spring at a local IAC contest...
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
Old 09-12-2011, 06:50 PM
RV8R999 RV8R999 is offline
Default Very nice
Awesome! Thanks for the detailed Post Darren and great timing as I just joined the IAC and am planning a Primary event in November. Your timing advice is something I've been looking for and will practice with your numbers and see how it works for me.
I also do not have inverted oil or fuel. How did the plane do on the 1/2 cuban inverted downline holding for 3 seconds? I've been purposefully keeping this segment very short, maybe 1 sec, for fear of spewing oil all over the place.
Well done!
Ken
Old 09-12-2011, 08:33 PM
mv031161's Avatar
mv031161 mv031161 is offline
Congrats! Wooohoooo! If anyone care tomjoin us, we are having the mason dixie clash at farmville, va the weekend on oct 8th! More news at iac19.org
Mitch V.
Semi-Retired in Tybee Island GA
2007 MX2 Nigel Lamb EX RBAR MX2 (Current)
2020 MX2 New Kit Position (Sold at OSH to Team RV Member)
2009 Team Rocket F1 (Sold)
2008 MXS Green Slime"(Sold)
2007 MX2 Patches" (Sold)
1999 Giles 202 "Primal Fear/Perucho" (Sold)
1965 PA32-260 "God Bless America" (Sold)
2003 RV6 "Airhawk One" (Sold)
Old 09-12-2011, 08:47 PM
Thanks for the kudos fellas. It sure was fun. Can't wait for next year.
Ken as for the Cuban 8 inverted portion of the sequence: I didn't notice any change in oil pressure. It's a quick 3 count so probably 2 full seconds. The key is to keep the line before the roll the same as after the roll. After the roll it's a quick 2 count.
I have an Advanced 3500 EFIS so maybe there is a delay in oil pressure reading ?? I don't know but it doesn't move at all in the brief time inverted. Also, I run 5 quarts of oil. Any more and it all comes out the breather tube and ends up on my tailwheel. After the two days of flying at the contest the oil level is only down slightly. There is fresh oil on the tailwheel so I know some oil came out.
I was reading last night that some guys put in something called an "oil accumulator". It is a pressurized tank, about 12" long, that will shoot oil into the engine as soon as the oil pressure drops. One guy says it will provide 7 full seconds of inverted oil pressure. At least I think that's how it works.
Maybe something to look into. My engine is Fuel injected with a flop tube so there was no fuel issues.
Entry speed to the first manoeuvre was about 145 - 150 knots. After that I don't watch speed till after the half Cuban when I want to see the same speed before the loop. Again, the more aggressive the pull into the loop the more speed and inertia you lose and the more difficult it is to make a nice round loop.
Good luck in November!!
Darren
Old 09-13-2011, 12:48 AM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
Aeros v Inverted Oil systems can be a long topic.
Firstly, as Darren says, the Cuban lines need to be the same length. Given the speed change on the way down, then count to 3, roll, count to 2, about right. It does not matter how quick you count, so long as it is the same pace I can assure you the 3 count does not take 3s!
We have on the RV-8 the oil tank of a Raven system - this collects oil trying to escape via the breather, and returns it to the sump when upright. So it minimises Oil loss / dirty belly. However, it does nothing to keep Oil P up.
An Oil Accumulator will be the opposite - it will do nothing to prevent Oil Loss, but will keep the Oil P up. I would not worry about a few seconds decreasing Oil P for the engine - unless you have a C/S prop and it leads to a significant overspeed.
I reckon I can get 2-3s actual inverted flight before I hear the RPM increasing. See 4:47 in this Video
All in all, a great account of a 1st contest - I remember mine
Andy & Ellie Hill
RV-8 G-HILZ
RV8tors
Old 09-13-2011, 04:01 AM
Default Get video Andy!
Andy,
That video of your airshow performancewas excellent- you can really get a sense of what these aicraft can do with capable hands! Good show!
Brent Owens
Columbus, OH
N784DE S/N #82614
Old 09-13-2011, 07:28 AM
sandifer sandifer is offline
Great job Darren! I remember your practice videos and knew you would do well. Keep it up. Curious, how many other RVs flew the contest?
