Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
  #11
Old 09-14-2011, 01:06 PM
Gonzo24 Gonzo24 is offline
Default perfect
You guys hit it right on the head! Personally I was thinking that if I don't alumiprep, alodine and epoxy prime the pins before I crimp then they may fall off as I am doing an overhead break at a non towered, congested airfield full of RV haters.
Hey anyone going to Reno to get away from the hot WX in TX? I should be using slick mags with the red paint job I'm planning anyway. better use the 74" prop instead of the 72 with composite blades... could explode.
Built 7A flew 700+ hrs - sold
- 7 flying
Old 09-15-2011, 12:03 AM
mlwynn mlwynn is offline
Default Crimp or Solder
I have been scratching my head about this as well. My main issue is that I would like to finish the wiring from the ignition switches to the LSE modules before I permanently mount the engine. The wires soldered the to connector that go to the ignition switches are going to be a pain to route once I rivet on the front top skin.
Klaus is pretty adamant about leaving his wires soldered on. Another builder told me he had an issue with cold solder connections.
I am a big believer in the advantages of the crimped connectors. Still, I worry that I will somehow foul stuff up by cutting off the soldered connectors and crimping my own. Can anyone direct me to other discussions on the subject?
Decisions, decisions.
Regards,
Michael Wynn
RV 8 Wiring
San Ramon, CA
Old 09-15-2011, 05:21 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Understand where Klaus is coming from. He's probably aftaid that if you cut off the wires and re-pin them, you'll make a mistake and then blame his unit for some problem. I understand his position and don't blame him.
But, wiring is not black magic. If it makes it easier to cut the connector off, CUT IT OFF! It's just crimps and pins. No big deal as long as you have the right tool, quality pins, and the proper receptacle. Go for it, no need to torture yourself over it. I found crimping the pins to result in a better connection than me trying to clumsily get my solder iron on the right pin, etc. Crimp and snap, you're done! Call SteinAir and get the stuff to do it right and you'll be a happy camper.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 09-15-2011, 06:23 AM
Originally Posted by f1rocket View Post
Which "drift" would you prefer? We could try any of the following:
1. "If you solder any of your wires your airplane will fall out of the sky"
2. "Why have electronic ignition, it doesn't save you anything"
3. "You should switch from LSE to (pick your ignition) because it is better"
I'm sure there's a dozen more. Chime in with your favorite drift topics that would fit for this thread.
Magnetos are working fine so far.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 09-15-2011, 09:36 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Originally Posted by N941WR View Post
It will work better with a primmed tip-up tail dragger with fuel injection and a CS Catto prop.
Don't forget the chromed valve covers!
Neal Howard
Airplaneless once again...
Old 09-15-2011, 09:45 AM
AltonD's Avatar
AltonD AltonD is offline
ANY chrome added to an airplane makes it go faster. I added a chrome pitot tube and picked up at least 5 knots. Valve covers have to be good for at least 2-3 with the cowling on (5-6 on the ground with the cowling off).
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
